Panamera 2010-Current
Fuel Filler Flap - 2017 Panamera 4
Old 01-04-2018, 08:32 AM
TAG ceo
TAG ceo's Avatar
I find that pushing more towards the middle of the fuel filler door helps, it must be something in the way it flexes. Bottom line is on a car this expensive it just shouldn't happen.
Old 01-04-2018, 10:34 AM
MarekO
3rd Gear
MarekO's Avatar
Originally Posted by thorfun
yep! or at least I can't tell if they were pre-painted or done at the dealership. both look the same colour as the car.
No painting necessary, flap stays You´re old one, problem is with filler flap module, basically all earlier Panameras have it.
It´s not ok if you have to use force.
It´s a little bit less then 1h work to change it.
Old 01-04-2018, 01:46 PM
Wing Commander
Wing Commander's Avatar
Received 1,178 Likes on 434 Posts
Thank you - good to know & very helpful. Cheers!
Old 01-04-2018, 02:06 PM
Taffy66
Taffy66's Avatar
My July delivery Panamera hybrid with the same issues had whatever parts replaced under warranty however the problem still persisted..My month old Panamera has had no issues so far...fingers crossed..!.I still believe its a common factory fault on early Panameras where the actual fuel flap is misaligned ie the flap is set too far towards the rear so when the release catch is pressed the flap just catches on the edge..I found this out when i was stranded and i used my credit card to prise it open...This worked every time..
Old 01-05-2018, 07:21 AM
MarekO
3rd Gear
MarekO's Avatar
Maybe You´re panamera didn´t get the newer modifyd module? Spare part changes part no.
Visually there is no difference with two parts, but some dimensions etc is defenitly different on new module.
Anyway they have to fix it under warranty.
Old 01-05-2018, 10:08 AM
NorthernMonkey
NorthernMonkey's Avatar
had same issue on my 2017 Panamera 4...also the outer body colour flap didn't seem to sit flush as it should with rear haunch. OPC replaced the whole plastic section of the fuel filler flap basically everything that sits beneath the body coloured cover. now it is not only a LOT easier and more consistent to open but it also sits flush rest of that panel as it should.
Old 01-05-2018, 01:07 PM
Wing Commander
Good to hear, NorthernMonkey. Thank you.
Old 03-09-2018, 12:12 PM
mm1
mm1's Avatar
Had the same issue on my 2 week old car. My wife was almost stranded and called me, quick search and found this thread and called her back. On my first fuel up it seemed odd and maybe the colder temps made this more pronounced. Either way, next service I'll have them look at it as it's annoying on a 100K+ car.
Old 03-09-2018, 12:25 PM
Wing Commander
Absolutely! Good luck with getting it sorted out.
Within the next few weeks I'm trading my 2017 Panamera 4 for a new 911 Carrera T. Looking forward to much easier fill ups at the petrol station!
Old 03-09-2018, 12:52 PM
K777
K777's Avatar
Look at the catch sticking out on the body, not the flap.
Above it and below it is a slightly raised part.
That needs filing down a little bit then there will be no issues.
My biz partners was bad, Porsche Leeds filed them off and no problems since. Sept 2017 car.
They did it on my Dec.17 car as a matter of course without asking, and no issues since.
Anyone reading this in future if your stuck - inside the boot behind the material panel is a red hook to manually undo the flap.
There's a hook inside the boot for the electric flap too.
Old 03-09-2018, 12:55 PM
K777
K777's Avatar
Old 03-09-2018, 03:39 PM
SaratogaLefty
SaratogaLefty's Avatar
Originally Posted by K777
Its not clear to me exactly which areas were filed down?? Are you talking about the rounded edges of the cross piece and if so how much filing down does it need?
Old 03-09-2018, 03:42 PM
Wing Commander
I think it's the area just above and just below the round cylinder-shaped part. Looks like all of the filing down has already been done...
Old 03-13-2018, 06:12 AM
K777
K777's Avatar
sorry guys was away for the weekend:
I didn't notice what they were like before so don't know how much they took off.
Old 03-13-2018, 01:24 PM
knowspin
knowspin's Avatar
My wife mentioned the other day that it amazes her Porsche does not have a fuel filler release button inside the cabin. She's right, all our other cars have that function.
Quick Reply: Fuel Filler Flap - 2017 Panamera 4
