Oil Change - 2017 Panamera 4
You should have a separate booklet titled "Maintenance". It's for all the maintenance intervals of everything you need to tend to on the car. I would check with your dealer.It does seem odd that there is such a disparity in oil change levels. However, I have a LS460 as my daily driver and the automatic transmission is sealed and requires no maintenance. On a Lexus website I'm on, folks in Canada says their manual calls for a fluid change at 60,000 miles. So for whatever reason the specs are different for different countries.
Mark, I couldn't find anywhere in the manual what the oil capacity is. I was wondering if Porsche didn't tell you to make it more difficult to do your own maintenance. I'm going to have to find out for my engine. Fortunately the first service is free so I'll find out then.
As an aside, I think its cool that you can see the oil level from one of the dash readouts (I hope its accurate).
I've a service booklet in the car, which is stamped for servicing and oil changes etc. I'll check it again, but don't recall seeing in there about recommended oil change intervals...
Goodnight, all.
Goodnight, all.
