Can this be programmed in Porsches?
Can the following features be programmed in Porsches (specifically panamera)
Sport Exhaust valves open by default instead of having to hit the console button each time
Footwell lights on all the time when dark
Is the dealer the only one that can do these, if it's even possible?
I am referring to a computer modification tot he coding on the ECU to allow valves to stay open. by defualt so the light on the exhaust button is always on instead of off unless you turn it off
As far as I'm aware it's not linked to the ECU or any management system that can be configured. It's a switch that operates a vacuum / exhaust valves. Removing that vacuum hose (shown) basically bypasses the switch i.e. It's on all the time
