PSCB Grab
Hi folks,
My (new to me) 2020 Turbo has PSCB, which I believe are standard on the Turbo. I have to admit that I've been having a tougher time than I expected adjusting to how much they initially grab. I like strong brakes but I wasn't expecting them to be so grabby with very little pedal push. When pulling into the garage, etc it's quite difficult to do so smoothly. I just want to make sure that this is standard behavior for the PSCB and that there isn't something wrong ... |
standard behavior, though doesn't happen consistently
I had a lot of miles on my 911's PCCB, so used to a grabby brake. Hard though, when you're trying to be careful pulling into the garage. |
Keeping them clean helps a LOT, as does keeping them warmed up.
PSCBs are wonderful brakes when they are hot, but getting heat into a Porsche's brakes in street driving often entails risk to one's driver's license and/or sheetmetal. I've resorted to dragging the brakes for a quarter-mile or so on occasion. That works... for a while. Edit: another tip that helps keep you from looking like a spaz in parking lots and drive-thrus: switch the drive mode to Normal temporarily. By lowering the idle, this will help you stay off the brakes and enable smoother driving/parking maneuvers at very low speeds. |
They are grabby. And it is somewhat inconsistent, as in sometimes they grab more or less so. I have not found keeping them clean makes any noticeable difference however others here and in other threads have stated they felt it does. They are great brakes otherwise.
Thanks, all. Glad to know that this is just their normal behavior. I'm sure I'll get used to them more and more in time.
Originally Posted by mark8
(Post 19403488)
Mine are not grabby enough. I have to apply more pressure on the brake pedal than I did to the steel brakes on my 2017 GTS. It almost feels like they are ceramic brake pads that have no bite to them.
Originally Posted by NickS
(Post 19414897)
(Post 19414989)
Wow, that's interesting. What year is your Macan? and are they definitely PSCB, not PCCB?
(Post 19415072)
2024 GTS and they come standard with PSCB's. What I don't know is if Porsche changed pad compounds from those of the previous years with PSCB's due to complaints and now the 24's might be slightly less grabby? I'm not complaining about the effectiveness of my brakes either. I just wish mine had more initial bite.
