Macan EV: Only Porsche Dealers will be able to service it ?? :(
Right now with our Taycan one of the things I don’t like is that even tough the scheduled maintenance is super easy DIY, you cannot reset the service reminders yourself without a PIWIS. Not a huge deal if you have a buddy with one. However, I understand that with the Macan EV, not only will you need a PIWIS, but one that fully updated and actively connected to Stuttgart...in other words, only your authorized Porsche dealer will be able to reset service and code modules. Obviously, this is not something is being covered by Porsche's marketing materials. I can understand that the dealers want to protect their service revenue in the face of EVs becoming a larger segment of Porsche's product line.
Any truth to this?
Any truth to this?
I haven't heard of it but I'd fully believe it. I've been wondering how manufacturers are going to keep the daelerships happy with service revenue as the service department of a dealership can often float the entire dealership. EV's are effectively turning that revenue stream off significantly because of significantly less maintenance required while newish. Dealerships predominately only work on newer cars. So it makes sense and I have seen stuff like this creeping up for awhile.
New battery = Porsche thinks you should get it coded (why?)
lights disconnected on a car, off to the dealership it goes to recalibrate (why?)
Non self clearing codes for all kinds of systems that actually aren't a problem (low voltage is probably the worst one I see).
Going back further we had manufacturer specific tools (you can buy them but it's not logical to do so unless you specialize in that car specifically)
etc etc etc.
etc etc etc.
Zhao (02-19-2024)
I guess as cars get more complicated this was inevitable.
But I think third party shops - indie? - will be able to service them also.
Except perhaps for Porsche, it's not inevitable. It's literally called "protection of vehicle diagnosis"
https://static.nhtsa.gov/odi/tsbs/20...45118-0001.pdf
Some poor schlub had to implement that in the firmware, or be fired.
Not surprising since EVs require a lot less maintenance.
some math…
100 kWh "raw" capacity battery
95 kWh "usable"
"known" range @ 325 miles (according to Kyle's video
325 miles driven at 95 kwh leads to approximately 3.42 miles per kWh
my cost per-kWh on PG&E EV-A plan is $0.34 kWh "off peak"
cost per mile driven is therefore $0.34 / 3.42 = $0.099/mile
using 28 mpg as a factor and $4.50 gallon gasoline - cost per mile of the ICE macan is $0.16/mile driven
so $0.10 mile driven for the EV
and $0.16 mile driven for the ICE
YMMV literally - costs to drive are obviously very very dependent on your local ulility rates…
95 kWh "usable"
some math…
95 kWh "usable"
95 kWh "usable"
some math…
95 kWh "usable"
95 kWh "usable"
The following 2 users liked this post by usctrojanGT3:
daveo4porsche (02-22-2024),
Jeff Whitten (02-22-2024)
