New trick to stop oil filter leak- learned the hard way
Just did a oil and filter @900 mi. Used a new canister, i know the drill this is my 4th 981 2nd 4.
i get done and leave the car run while up on the lift and i notice some light oil film on the lip of the canister. Check the tightness and its good. So i pull off the filter again of course it slips out of my hand and dumps 10oz of hot oil on my head(unbelievable). So i replace the filter and canister again with another new one.Take the car for a ride and recheck same thing..now im pissed. So i got an idea that when the canister gets tightened the o-ring gets tension from the rotation. So what i did was loosed the filter 1/4 turn and re-tighten repeated it about 5 times then re-torqued . Took it out for a 20 mile test drive now its bone dry. From now on when i replace the filter im going to use a technique similar to tapping a hole. Once the o ring engages tighten 1/2 turn then back off 1/4. That way the o ring will seat completely and not be in tension. carl |
Ugh. You're putting oil or silicone grease on the oright during assembly right?
I can't change oil on my antiques without making a mess. |
Originally Posted by Spyerx
(Post 13629208)
I can't change oil on my antiques without making a mess. The worst Porsche i had for a oil change was a 993TT. Two filters and you had to remove the rear wheel liner plus an oil line. Dealer wanted 400+ and that was 20 years ago. An honest messy three hour job. |
I'm honestly to the point where I'll do many services myself but gladly pay the hour labor to have my shop do the oil changes on my gt3 especially since it gets oil changed a lot. Fulfilling? Sure. A hassle and messy as fk. Yup. Same wth axle boot replacements. Take my $$$
There may not have been a leak and you just noticed oil residue.
I have not experienced that problem in the past. Lubing the O ring is the only thing I do before spinning the filter onto the engine. Next time you remove the filter you might want to check the mating surfaces on the engine. Could be a small issue there that your new procedure negates.
i checked the surface it was perfect and the original didn't leak . I think it would be better to do the filter with the engine cold. next time ill pull the drain plug and let the oil drain overnight and do the filter in the morning. did that with my other 4 and the filter threads in much easier.
Interested to see if it changes.
Carl,
I put the LN spin on adapter on my Spyder to avoid some of filter issues. So far so good. Rob |
Originally Posted by Alan C.
(Post 13629785)
Hate being Having OCD..But Mobil 1 makes a great hair dressing . I had a face full. Carl |
Reminded me of Brillcream in high school. There slogan was a "little dab will do ya.".l used 10oz of 0-40 for the same look ..I Looked like the cast in Grease
If more hair starts growing, go file a patent :)
Originally Posted by 4carl
(Post 13630340)
Did 50 miles and put up to inspect ...bone dry.
What a pain. You are doing this with a lift? I'm not looking foward to tackling this with the car on jack stands.
