TPC or Tarrett toe links?
#46
Premium Sponsor
Thank you to Leong72 and JD-Motorsports for posting your experience! Your method of measuring toe deviation is sound. Same with many race teams, of course we check bump steer the old fashioned way with wheel off, no spring, and use dial indicators or string & machinist's rule. But when applicable(race cars with 1000+lbs springs aren't applicable) we also back it up with laser alignment machine afterwards to verify consistency. On alignment machine, it is done with wheels, tires, and springs which IS how we drive the cars, to which I feel this method is more actual than the old fashioned mechanical simulation, as the suspension parts are loaded and unloaded closer to actual driving conditions. Not knocking on the old fashioned method at all, we still do those too. As long as the alignment machine heads/fixtures are calibrated and attached properly the results will be the same. As for your specific before/after results, in percentage of reduction, it is better than ours because your car is running more negative camber. We are right at 50% reduction, whereas yours is greater than 50%. Well done, guys!
On a completely separate note, just wanted to share the following- Last week I received a phone call from a former Penske Racing engineer who owns a GT4. He saw the TPC GT4 offset rear toe links in a print ad and felt compelled to call us. He stated his intention of the call clearly in saying that I am not calling you to buy set, because I have custom made a set already for my car after doing the development myself. He came up with the same positive results as we did. He just called to give us his nod of approval for the idea and the product. For what little that's worth to everyone else, I felt honored that he took the time to call.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
#48
Premium Sponsor
No worries. Yes they will clear true 19" wheels. When I say true I mean the inside diameter of the wheel barrel was designed originally as 19's. Some wheel companies actual use 18" inner barrels and build the lip area up to 19". Obviously this 18/19" hybrid type wheels won't clear.
#49
#50
Premium Sponsor
Sorry, I should have phrased it differently. If the wheel in question clears the OEM rear toe link then it will clear TPC rear toe link as well. The TPC links is actually 2mm shallower than OEM at where the wheel barrel over laps.
#51
#52
Alright I may just have to give these TPC toe links a try on my GT4... TPC and all the other shops chiming into this thread seem like class acts that really know their stuff.
#53
Well, I guess I'm a little late to the party. I took measurements as promised, but haven't had a chance to do anything until this week. Sure enough, with rough GT4 dimensions, the effect of the offset bushing in my simulation is significantly larger. You can see that the TPC-style offset bushing has ~40% less toe change across the entire range of travel. For reference, I measured about 1/4" of offset on a TPC piece.
Sadly, no Faro Arm or similar was involved in my measurements. Small tweaks in the position of hardpoints in my ADAMS model show quite a large effect on the toe curve, so I wouldn't be inclined to rely on this for more than order of magnitude. Fortunately, there's plenty of on-vehicle test data to prove my original result wrong! So a very strong thank you to Leong72 for posting that.
#55
Glad to see the analysis roughly lines up with the empirical data. Thanks for taking the time to pull this analysis together and present the data so clearly!
