Originally Posted by Tom-TPC Racing
No problem clearing 19x11 as long as its a "true" 19-inch wheel. I mean I have seen some wheels that have ridges or raised areas inside the wheel barrel that takes up space. Don't know why but some companies make wheels like that.
Originally Posted by orthojoe
(Post 13396793)
Cool. So if an aftermarket link like the tarett clears my OZ wheels, so will the TPC.
Originally Posted by BGB Motorsports
(Post 13396792)
want me to snap some pics of the ClubSport rear suspension Tom?
Originally Posted by Errsomeone
(Post 13396493)
While I had planned to write a more complete message, this thread seems to be a good opportunity to add another account that echos TPC notes.
Quick bit about me: After years ago being heavily involved with DEs and then moving on to own and play race cars while traveling with a professional team I have taken quite a number of years away from being at the track. Recently I have just gotten to know TPC after they have setup my GT4 this season (street/track alignment, Cantrell roll bar, harnesses, brakes, etc). This past weekend I was at Watkins Glen and paddocked with Tom. Even though TPC has offered to let me try the DSC before, I had declined as I wanted to first get a sense for the car with making adjustments one step at a time as I got back involved. For the last session of the day I asked Tom if I could take him up on the offer to try the DSC to see what the difference is. Much like OrthoJoe's notes and true to TPC's description the DSC was certainly noticeable... Nose dive was greatly reduced and the car did feel more stable, specifically under heavy breaking. Reading the list over time I have seen a number of threads regarding a reduction of some number of seconds that the DSC may help achieve. While I believe that DSC will help in lap times, I think this may be missing some of the point as a lap time itself involves quite a number of factors. The increased stability is noticeable and could certainly contribute to such. In my case, the largest takeaway was a feeling that I could manage the tires grip better, particularly under breaking. For my data logging, I can simply say that in the last session where I used the DSC I did not have enough clear track or time to get what I would believe to be a valuable overlay for comparison but will be looking more closely at this in the coming days. Regarding purely lap times, I can say that my times were very similar between stock controller having open track, and using the DSC while managing to get through quite a bit of traffic. Overall, I do believe that the adjustments that the DSC made did provide increased stability that was valuable. I hope to get some useful data overlays between my sessions stock and the one I used the DSC to share. However, I can say that the DSC came home in my car :to_order: Completely agree with you regrading lap times. DSC does exactly what we depict it to do, which is improve vehicle weight transfer/stability in a dynamic manner. The difference is immediately noticeable. It is no placebo effect. However, as you said, this does not guarantee quicker lap times. Neither does, better brakes, tires, or even a set of $10K+ shocks. All these items do something very specific. It is up to the driver to enjoy and get the most out of the improved characteristics. In nearly all cases the improved vehicle weight transfer/stability makes the driver feel more confident/comfortable to drive the car quicker. PS- It was fun having you put the pressure on me from the mirror and then trying to keep up with you for a little while. |
Originally Posted by Mech33
Aren't your rear OZs 10" wide? I thought that is what Tire Tack listed for them on the GT4.
(Post 13396877)
Nope. I didn't want 10" because oem is 11". I got 19x11 et50, and it fits just fine with the tarett links. You have to call Damon to order the 19x11 wheels.
Ooo interesting... 11" et 50 is the exact same as stock! Odd that they don't recommend that one by default. Nicely done.
Originally Posted by myBailey07
(Post 13395611)
Joe, my question to you is, now that you know about the problem described by BGB, have you done anything to your rear suspension, other than toe links to dial in more camber?
(Post 13396888)
Yup. It's because they won't fit with oem toe links. Need to have aftermarket ones.
Originally Posted by Eric5280
(Post 13395693)
The product is a legitimate upgrade and is staying in my car. You really don't need to be a pro to feel the difference, it is that big. FYI, anyone in CO is welcome to try my unit at HPR if they like. Swap takes 5 min.
(Post 13396877)
Originally Posted by "
When we ran the Cayman we had a lot less rear tire AND we had a tire with a notoriously soft sidewall. There was deflection in the sidewall during the moment when you wanted to release the brakes and finish your turn-in just prior to apex and then there was toe deflections from the hard mounted toe link overpowering the rubber mounted control arm bushing. Swapping that inner rubber control arm flange for a Cup style monoball one fixed everything for us.
