My GT4 Modifications: CF, Decals, Roll Cage, etc.
After an excruciating wait that has become the right-of-passage for most GT4 owners, my Porsche arrived three weeks ago at Roger Penske's latest mega-dealership: Porsche of West Broward (Florida) – more about which will be described in a separate post in the Rennlist Florida region forum. Suffice to say, this dealership is HUGE – the biggest in the US and exceptionally impressive – from the team of seasoned professionals, to the architecturally impressive multilevel facility, to the fabulous espresso bar. Gotta see it!
So finally, with my new car in hand, I decided to demonstrate superhuman willpower and within days sent it to Pathfinder Motorsports (my brother's tuning, racing, and exotic car shop) for a couple of weeks to add some long-considered mods. I pickup my GT4 on Saturday, but I've already received some photos.
Stripes
With the Porsche 911R as an influence, I asked Pathfinder to design a similar set of stripes that would compliment the GT4's lines, as well as its Racing Yellow color. We decided on black stripes with a red outline. I've tried to infuse red here and there to pickup the red color of the brake calipers, so for example, even though I spec'd yellow contrasting thread for the interior, I elected to install red seat-belts. The stripes offer a bit more red color, and I will be installing red anodized tow loops fore and aft.
Model Name Decals
I have always liked the decal model designation found on GT cars like the GT3 RS and GT2 RS, and decided to eschew the raised lettering on the GT4 (and is standard on non-GT cars) and have Pathfinder apply their 'GT4' decal for the rear bumper and 'GT4 3.8' decals for the front door corners. After removing the standard letters with some monofilament attached to two large washers, the rear 'GT4' decal was applied and looked perfect. The door decals are slightly larger and include the '3.8' designation in lieu of the 'RS' that would otherwise be there.
Rear Wing
Unlike some on Reenlist, I think the GT4's rear wing looks mega! Being a unrepentant fan of the carbon fiber look (yes, that was fully optioned for my interior) I thought the rear wing would benefit from a touch of real unpainted CF. Pathfinder disassembled the wing and end plates and had actual CF 1x1 weave fabric applied to the wing, vacuum bag laminated, and hand finished. The final appearance is great, despite some minor flaws that betray that this is real CF and not vinyl or hydrophobic wrap.
Front Spoiler Lip & Rear Diffuser
With the wing now resplendent in high-speed/low-drag carbon fiber, I felt it important that the cuffs and collars matched, so we targeted the front spoiler lip and the rear diffuser. Pathfinder recommended against using real CF on these parts – too many twists, curves, and edges. Instead we elected to use carbon fiber hydrophobic wrap that matched the CF applied to the wing. The results were outstanding (and the cost substantially less than the wing).
Engine Fluids Trunk Plate
I'm still not clear what this thing in the trunk is actually called, but I've referred to it as the 'aluminum skate board' that every Cayman has straddling the two access points to the car's water and oil. Whatever it might be named, I always felt it was an eyesore that draws too much visual attention to an otherwise unimportant feature of the GT4. So what to do? Carbon fiber, of course! The plate was removed and hydrophobically wrapped in matching CF; it now is less visually prominent and, when spied, carries the carbon fiber theme found elsewhere on the car. Pathfinder was able to replace the protective rubber rub-strakes perfectly, giving it a factory appearance.
Canard/Dive Planes
Doesn't a rear wing require a front wing – a couple of canards – to balance things aerodynamically and aesthetically? Out of the box, the GT4 tends to display mild understeer which can be mitigated with adjustments to the front and rear sway bars, but perhaps some modest downforce from dive planes might help! My wind tunnel is currently being used to store gennakers, mizzen sails, and spinnaker poles, so I'm unable to validate with any scientific precision the impact of the small, almost dainty CF canards Pathfinder built for me, but as they're attached with 3M double-sided tape, this isn't a lifetime commitment. I can say with scientific precision that they look great and make me smile!
Roll Cage
My GT4 will be spending many weekends at track events, most especially at Sebring and PBIR, so a roll cage is a smart option. And, of course, the right roll cage also accentuates the 'GT' heritage that the GT4 has inherited – nothing sexier than a GT3 RS with a color-matched roll cage! Having researched what was available for the GT4, I decided on the GMG roll cage due to its design, the reputation of the company, and the bolt-in nature of the installation. GMG's Dom Bautista was great to work with, and Pathfinder had the roll cage sent to Porsche of West Broward where it was installed the same day it came off the truck. It looks absolutely factory-built and installed, and surprisingly has minimal impact on rearview vision. Everyone that sees it says it really makes the car standout and I'm really happy with the result.
Aluminum Pedals
After seeing the standard pedals offered by the factory I was underwhelmed, even more so when I saw the $535 aluminum pedal upgrade offered as an option. Not wanting pedals from the Buick parts bin, I found a nice set of 'Porsche' labeled aluminum race-car style pedals on eBay - $77 bucks. Installed by West Broward Porsche, you tell me which looks better:
Factory option aluminum pedals for the GT4: $535
eBay Porsche-labeled aluminum pedals: $77
Radar Detector
As an owner of a Valentine 1 radar detector I find that, due to the inconvenience and mess associated with plugging in the power cable and attaching the suction cups onto the windshield, often times I don't bother with it at all. With the GT4's compelling need for speed, I figured a good solution would be a professionally installed detector with remote control over its operation. Valentine offers a remote control module that can be installed anywhere while allowing the detector itself to sit in an optimally high location with good forward and rear 'vision', and Pathfinder did a perfect installation. The remote control is to the right of the steering wheel and just below the dash – easy to see and access while being relatively hidden from view. The detector itself is located overhead adjacent to the driver's side sunshade and all of the wires are concealed. Sweet!
Remote on/off and volume control unit for the Valentine 1 radar dector
Remote Valentine 1 alert indicator mounted above the driver's visor; the actual radar detector is mounted amidship on the ceiling roll bar behind the seats offering perfect front/rear reception
Miscellaneous
Had a couple of decals that needed a home, including a classic Porsche engine displacement rear window decal, so on they went.
A side note: One of the delights of Porsche ownership is the acceptance by the Porsche community of owner modifications, recognizing that part of the fun of car ownership is converting it to reflect your own taste and driving preferences. This laissez faire attitude is in stark contrast with my experience with the Ferrari community, where the prevailing almost cult-like dogma is 'don't mess with what Enzo intended'. A post like this describing similar mods to an F430, for example, would be seen as apostasy and banishment from the community of Ferraristas.
Well, that about covers my first stab at GT4 modifications. Thanks to Dr. Phil Gandini for his kind suggestions on GT4 vivisection. I'll periodically update this post with additional photos of new mods, moded mods, and anything that might be of interest to fellow Rennlisters.
Stripes
Model Name Decals
Rear Wing
Canard/Dive Planes
Roll Cage
Aluminum Pedals
Radar Detector
Miscellaneous
So, finally, with my new car, in hand I decided to demonstrate superhuman willpower and within a week sent it to Pathfinder Motorsports (my brother's tuning, racing, and exotic car shop) for a couple of weeks to add some long-considered mods. I pickup my GT4 on Saturday, but I've already received some photos.
Stripes
Model Name Decals
Rear Wing
With the wing now resplendent in high-speed/low-drag carbon fiber, I felt it important that the cuffs and colors matched, so we targeted the front spoiler lip and the rear diffuser. Pathfinder recommended against using real CF on these parts – too many twists, curves, and edges. Instead we elected to use carbon fiber hydrophobic wrap that matched the CF applied to the wing. The results were outstanding (and the cost substantially less than the wing).
Canard/Dive Planes
Roll Cage
Aluminum Pedals
Radar Detector
Remote control unit for the Valentine 1 radar dector
Ceiling mounted Valentine 1
Miscellaneous
Stripes
Model Name Decals
Rear Wing
Canard/Dive Planes
Roll Cage
Aluminum Pedals
Radar Detector
Miscellaneous
I like majority of the stuff you did. That carbon fiber wing looks freaking sweet.
Personally I could go without the porsche R inspired decal and all the "3.8" decals...especially the one in the rear hatch. That rear hatch looks so pretty with the roll bar and the CF trunk plate. That 3.8 engine decal is a real distraction IMO. Sometimes less is more.
I love that you made this GT4 yours! More power to you and I love the R inspired stripes and the carbon enhancements.
Basic Sponsor
Kim,
Thanks for the support for our GMG products.
Dom has been doing a terrific job at GMG and we are happy you are enjoying our GMG Harness Bar.
Let us know if there is anything else you need.
Cheers,
Cheers,
James F. Sofronas | President & Owner
Global Motorsports Group ™
E: james@gmgracing.com
P: +1 (714) 432-1582
F: +1 (714) 432-1590
A: 3210 South Shannon Street, Santa Ana, California 92704
W: gmgracing.com
W: gmgracing.com
last time I checked 4.0 is straight A's
time to send it to BGB
I need that carbon fiber wing...
Great write up and pics. Car looks great and very custom!
The GT4 decal and the CF wing are really superb.
Congrats
Hi five on your mods !!!
Best of luck with the car its a beauty
Regards
Ed
Regards
Ed
Well done Kim! Clearly you took your time to plan this, and the execution, through your brother's shop, is very high quality. I can say from personal experience removing that rear plate between the fillers is a real PITA--it's held on with about 30 folded over tabs, then double sided taped...and it's thin enough to bend and crease. Oy vey! (I decided to paint mine...even though I did wrap the one in my GTS.)
I have only seen the hydrophyllic finish once in person. What is its scratch resistance--like vinyl wrap, or more like paint?
Thanks for the great photos and nice write up! Now go out and drive that baby...
