Deletion of model designation
Does anyone Spec this? Let's see some photos!
Do they move the "PORSCHE" logo lower after the "GT4" is removed or does the "PORSCHE" stay at the same location? Thanks in advance! |
Looks so much better. Thanks Pete. Do you know if they move the "PORSCHE" lower compare to no model deletion?
yes, the "PORSCHE" is moved down to stay in centre
Judging by the 3D configurator, yes they do move it down.
Too bad that they don't give you the option to have just "GT4" on the back, like the 996 GT3.
Originally Posted by mikehinton
(Post 12602024)
Probably is does. Would be nice to be able to order it that way. I might be willing to give up leather-covered vents in exchange! :D
Originally Posted by gmaki
(Post 12602097)
But if you simply remove the "P O R S C H E" yourself doesn't that leave "GT4" in the right spot?
A bit off-topic, but I've always wondered how clear bra installation shops that do full coverage replace the badging in exactly the right place, especially the Porsche badge that's all individual letters. I believe the spacing and alignment of the badge in and of itself is already handled because the whole thing arrives on a single piece of adhesive in the proper arrangement, but I've never figured out how the shops place the badge back at the exactly correct coordinates on the bumper. You wouldn't be able to mark the bumper prior to removing the badge because you'd have to remove that mark before putting the clear bra on. Just to satisfy my curiosity, does anyone know?
They do not remove the letterings. They cut a big rectangular hole to accommodate, I saw a GT4 with a full xpel wrap last weekend.
Originally Posted by Mc21
(Post 12602371)
Just reporting what I saw.
I had 2 lotus' before and when you order the "L O T U S" rear badge, they provide a stencil for you. Not sure if Porsche does the same. |
Most exterior badges are OEM installed with something like double stick VHB tape.
Same for the GT4? Someone want to run dental floss below one to test it? |
