GT4 - Unlocking the Power Potential!
#406
http://youtu.be/ErwHFPyH0pI
I haven't driven it as I'm sick as a dog at home but hopefully tomorrow I get to drive it, flash it and dyno it.
Congrats
Great job and look foward to seeing it with wheels on it
In car video is a must
#407
Basic Sponsor
Thanks. I still need to do some work and check it for drivability, oddball behavior and then build a proper file for it. Thank you all for cheering us on!
#408
Get well soon
Can I bolt the X51 intake manifold (+plenum +TB +header +tune) on without modifying the heads or else would it create too much turbulence without having the X51 ported heads?
#410
This thing sounds mean and you don't even have on a cargraphics rear exhaust.
#411
Way to go John. Hope you're feeling better.
#412
Basic Sponsor
Thanks guys. It's just the run of the mill flu; I took the afternoon off but it's killing me not knowing how the thing drives so I'm headed in, albeit a bit slowly. I shall report more later this AM.
#413
Car sounds great.
#414
This is bigger than any one person John - you need to get some tamiflu and get back in the shop and fight!
#416
Basic Sponsor
OH MY GOODNESS this thing rips over 5K RPM!! It's actually a little scary which is all I ever wanted. The noise level is actually not as bad with the PSE closed; when open, it's rather loud. The torque down low is solid via the headers and flywheel. The X51 we know shines over 5K RPM via the porting, manifold and cams so everything is behaving as expected and I'm still on the stock tune!! At the end of the day, these cars should make so much top end that you're afraid to run it to the RPM cut and now I finally have what I wanted.
#419
