Bilstein Clubsport damper settings on a GT4
I have a set of these going on now. They have adjustable compression and rebound damping on a scale of 1 to 10, with 1 being softest.
Who has gone through the learning curve and arrived at settings you like? What are they, and what did you learn? Thanks in advance. |
Paging @Mvez , though he is running custom spring rates and custom valving on his Bilsteins as far as I recall.
Haha! I sent him a private message, but posted this to cast a wider net in case there are others running the same gear.
Nice! Out of curiosity, where did you order them from? Look forward to hearing your feedback
Montaver, these came from Summit Racing, after backorder.
Originally Posted by Scott O'Connor
(Post 18273054)
Originally Posted by Montaver
(Post 18273060)
How long did they take to arrive? Don't see them on the website, although I do see some KW 3 ways on there
Supreme power had a couple sets in stock as if couple weeks ago. My OEM struts were leaking and I considered these. Curious how they will work out for you.
I got some feedback in a private message, to set the front compression at 4-5 and the rear at 6-7, with rebound set 1-2 clicks higher than that at each end. So, that's where I'll start.
Would these work with immocars rear camber plates? If they reuse the stock top mounts I assume so
Do these come with top mounts to adjust camber or reuse stock?
My car already had adjustable top plates.
(Post 18302912)
Actually finally sending my M3 Clubsports in after 6-7 years use for a re-valve and re-fresh. It's a great package. |
Feels great, and I haven't changed from those settings.
(Post 18686204)
They are sooo good on track, and have great street manners when turned down. |
