Originally Posted by Jim981CS
(Post 17851114)
Porsche does not recommend using anti seize and is probably one of the reasons that they recommend every four years even if low mileage on the plugs.
Jim |
As an update to this thread I've had issues finding the stud kit. Had it ordered from Amazon and then got a note they weren't being shipped as they didn't have them anymore. Have tried a couple different vendors with no luck. Thank you supply chain...
Really would like the studs instead of reusing the original bolts but I'm getting tired of looking at the headers sitting on my workbench! Oh well... (so instead today I took both 914's for a nice drive as luckily the weather here is a big improvement from my old home in Des Moines right now!!) |
I'm selling a BGB coil pack heat shield kit: https://rennlist.com/forums/market/1285082
https://cimg1.ibsrv.net/gimg/rennlis...f2ca245181.png https://cimg6.ibsrv.net/gimg/rennlis...5ff09c1b9a.jpg |
Still can't find the studs anywhere. Vendors are saying anything from late February to April! May just go with new bolts from Porsche... getting tired of looking at the headers on my workbench!!
If anyone has a reliable source, please PM me. Found some 1.5" in length, but afraid they're too short. |
Originally Posted by skl
(Post 17930687)
Originally Posted by Last_935
(Post 17845566)
Be carful reinstalling the header bolts. It is easy to cross thread them going into the aluminum block resulting in a major headache. Thread them in by hand as far as you can, feeling for any resistance. Then torque them to the proper spec. Better yet, install header studs. They make the job much easier and are not as prone to loosening and fall out over time.
https://bringatrailer.com/listing/po...ign=2022-01-26 |
Originally Posted by smlporsche
(Post 17932820)
sorry to hijack this thread but is this your ride?
https://bringatrailer.com/listing/po...ign=2022-01-26 https://www.supercars.net/blog/1984-...93584-gallery/ |
Got the headers in- a little more complicated that I thought, getting all the O2 sensors etc to fit the new headers and mini-cats. Sounds great but I immediately got 4 engine codes and 2 PSM codes. Cleared them and they came right back.
Engine codes P2305, P0352, U418, P0302. Says driving permitted. PSM codes 28688/7010, 28672/7000. Says driving adapting permitted. Guess I can figure the engine codes but figured the little mini-cats would work for a while! No idea why PSM should be affected unless I somehow loosened a wire somewhere in the process. Will check tomorrow. Taking a 914 home from my shop- no worry about codes with that car!!! |
(Post 17958996)
Engine codes P2305, P0352, U418, P0302. Says driving permitted. PSM codes 28688/7010, 28672/7000. Says driving adapting permitted. Guess I can figure the engine codes but figured the little mini-cats would work for a while! Did you end up using the factory bolts or were you able to find the stud kits? |
Found studs but a little longer- worked but would have preferred ones shorter so I didn't have to use a deep socket. Not a lot of room with a couple of the studs!
Didn't have to time today to play it more- had to pick up a new toy, a new Bronco!! Finally came after waiting since last summer... and it has all its chips! |
Header install update- finally had some time to figure out codes, etc. Got new coilpaks from Suncoast and went to install- found a loose connection to #2 cylinder coil pak (code was saying #2) so just reconnected it. Cleared codes and restarted car. NO codes! Took a short 6-7 mile ride, no codes, no problems. Car sounds awesome- has a nice bark in Sport +.
GT race headers, with the small Fabspeed mini-cats. Maybe I'd get a smog code in a few hundred miles but I plan on getting a Softronic tune with added code for no cats so it won't matter. I'll get around to installing the new coil paks one of these days... |
Nice find on the coil pack plug. If you happen to have luck with the mini-cats, please lmk or post up!
Congrats on the Bronco! Love the new ones. I hope they didn't do you wrong on the mark-up situation. |
Bronco is great- nice to have a vehicle I can drive on a gravel road! Luckily we have a dealer here who won't sell over MSRP... hope I'm not in trouble posting a pic of a non P car... ;)
https://cimg5.ibsrv.net/gimg/rennlis...b8d5e9dc21.jpg |
(Post 17988437)
I had fabspeed sport headers and ended up one year having to put OEM headers back on to clear the CEL. Mini cats didn't work for me.
Now I have the DeMan 4.5L with catless headers. Sound is sublime - hardly any difference with valves closed. I tip for anyone reading this in the future - USE THE OEM GASKET for the headers. I used one supplied with the sport headers and it was a disaster - a lot of header bolts fell out before I figured out what was going on. Also there is a torque order. And, if you use the OEM bolts, I had to grind down the socket to be thin-walled to clear the OEM exhaust. |
