Porsche Track Precision App help
I am having trouble with the Wifi connection when trying to connect to my GT4. After putting in the password in the proper format GTx (vin #). It connects yet I get the following error message: "a checkmark next to the wifi and saying no internet connection." See picture. Does anyone have a suggestion on how to connect properly? Is there a setting that I need to change?
Thanks.
Why no connection?
Thanks.
Why no connection?
jackippo (07-14-2020)
No worries, totally normal. It just means you're connecting to the car wifi and the car doesn't have internet. That's correct and your phone should still pull gps and internet over cellular.
FYI, this is all because bt doesn't have the bandwidth needed for the track app so even though your phone may be connected via bt a WiFi connection is required for the track app.
Thanks.
Why no connection?
Thanks.
Why no connection?
Hi, I had my app running perfectly and have been using it for 2 years. I had to reset my iphone X a few weeks ago. I was a the track last Monday and when I went to use the app I noticed I had to reconnect again. Once I put the information back into the app, inputting the Vin number, it connected but I am having the same issue. "no internet connection", at first I thought it was because of very bad service at the track. I went home and tried it once again and even though connected to hot spot in my GT3, it says no internet connection. I read your reply and still can not see how to fix the issue, maybe I missed something, any information would be greatly appreciated. Thanks!
jackippo (07-28-2020)
You are correct, it states no internet connection, that is the correct way. once I reset my iPhone and reconnected it worked fine. All fixed.
