best battery tender for car
Received 5,388 Likes
Buy Porsche's or C-Teks. Is your battery lead acid or AGM?
Its a charger that is fully controllable with temperature compensation. Not a toy like all others.
CTEK MUS 4.3 Polar
I bought the orange CTEK MUS 4.3 Polar. I liked that CTEK is the OEM manufacturer of Porsche-branded chargers, and the 4.3 Polar was the fastest consumer charger that CTEK made when I bought mine. Even today, if you compare the spec sheets, it is faster than the higher amp model that is out now. The pulse recondition feature can be switched off, which I also liked. And this can be used all the way down to -22 degrees F. I bought the cigarette lighter adapter and I charge/maintain without opening the front hood.
can't go wrong with ctek, but battery tender, noco and black n decker are all fine - schumacher has gone downhill with quality in recent years
faster is not better as a true tender/maintainer - whose essential function is keep a good car battery healthy over long periods of non use
a rapid charger or jump starter serves a different purpose
The only good thing about them is they are better than not using a charger at all.
Careful what you hook up if your Porsche is under warranty !!!! If an electrical issue occurs and you use a non-Porsche brand tender or a tender not recommended by Porsche the warranty ‘could’ be voided.
TurboS_GG (12-06-2019)
I own two of the CTEKs. After the tactile switch failed on one of them, I opened it up. Really poor quality in the way of solder joints. Nothing to write home about.
I also ran it on my data logger. Not as advertised.
IXLR8 - got it and understand. As I mentioned, in the USA things are different than here in Europe so probably not an issue of one connects a tender box from a company other than Porsche, I.e., CTEK.
Received 3,365 Likes
I have never used anything but these on my cars and bikes, and they always do what they are supposed to and I never had one fail: http://www.batterytender.com/
If that is their spec, I sure hope it does not charge at 12V (I know it doesn't, but tell me where Absorption cuts off at)
Whereas a company like Xantrex has specs where I am not guessing and we verified them in the lab (amongst so many chargers that promise you the world). But like I said, you need to know something about chargers and batteries. I can understand that many consumers really do not care, which is fine.
And that is the tip of the iceberg when you look at Xantrex specs.
If it matters to someone a call to Battery Tender will provide as much information as one desires...not sure why it is not on their web site.
I tried that Bob. They come back and claim their charge algorithm is proprietary , as if I can't determine it using any data logger which is what I use. There is nothing proprietary about it. You have to follow what a battery manufacture requires.
