European Delivery and or Porsche Experience Center This forum to ask questions and get answers about collecting your Porsche in Europe or the outstanding Porsche Experience Center.
How to Remove the Dummy Key
Old 07-02-2016, 10:33 PM
Need4S
Need4S's Avatar
Default How to Remove the Dummy Key
So, you have Porsche Entry & Drive, and either you or the delivery person inserted the dummy key. Very handy. You drive the car around Europe enjoying the keyless entry and drive feature, and now it's time to return your car to be shipped to the states.
You of course need to leave one of the electronic keys with the car, but you're not entirely comfortable that the key and the car will stay together on the long voyage. You want to remove the dummy key, and insert the "real" key (one of the two electronic ones) in its place in the ignition slot. BUT! Your dummy key is in the ignition and it seems stuck!
Well, it's supposed to be "stuck." DO NOT TRY TO FORCEFULLY REMOVE IT! Instead, here is the way to remove the dummy key so you can insert the coded electronic key.
1. Sit in car WITHOUT your electronic key. Not in your pocket or purse. It has to be outside the car's sensing range. I think outside the car is good enough.
2. Turn the dummy key as if you're trying to start the car.
3. You will see a message on the multi-purpose screen: "Key Not Recognized"
4. Turn the dummy key again as if you're trying to start the car.
5. You will see a message on the multi-purpose screen: "Operating part: turn left, pull off, insert key."
6. As instructed, turn dummy key to the left, you will hear a click, and you can remove the dummy key!
Take the dummy key home with you along with all the other loose things you're supposed to take (owner's manual, etc.). LEAVE one electronic key with the attendant (or in the ignition slot), and take the other with you.
Re-insert the dummy key when the car is returned to you at your local dealer and enjoy keyless entry and drive.
This sequence is also useful when you get back to the states and for some reason, worry the parking valet might lose your electronic key.
barrios35 (08-06-2020)
Old 07-04-2016, 12:53 AM
TorqueChap
TorqueChap's Avatar
Brilliant post. Thank you.
Old 07-11-2016, 10:59 AM
STALKER99
STALKER99's Avatar
Thanks for tip.
Old 07-26-2016, 11:35 AM
RESP
RESP's Avatar
Thank you for this tip!
Worked like a charm.
Maybe this should be a sticky??
Or cross post on a technical forum??
Old 07-27-2016, 08:23 PM
major dad
major dad's Avatar
Re laeving the key on the slot, one it drains the battery but more importantly my doors are set to auto lock after about 30 secs !
Old 10-19-2018, 08:05 PM
Pmorritt
Pmorritt's Avatar
old post, but i wanted to remove dummy. great info. thanks
Old 10-20-2018, 01:47 AM
Fred R. C4S
Fred R. C4S's Avatar
Dropped off my 911 Entry and Drive with one key. Was told to keep the rest. Car got from Stuttgart to Springfield Illinois without a hitch. I think they've been doing this for a while. No worries. How do you think they ship the cars normally? Trust me, thousands of cars and thousands of keys make the journey safely.
Old 10-23-2018, 01:11 PM
Kinnebrew Motors
Former Vendor
Kinnebrew Motors's Avatar
My 2010 Panamera with PED will not lock the doors if the key is inside.
Old 05-26-2021, 12:41 AM
M3Inline6
M3Inline6's Avatar
Received 1,305 Likes on 727 Posts
Does this work on the 992 as well?
Old 11-21-2021, 02:50 PM
Chaos
Chaos's Avatar
Thanks, search on start stop switch didn't get me here.
Old 11-30-2022, 07:40 AM
amtelson1981
amtelson1981's Avatar
Default Dummy key
Can you only use a dummy key if you have the keyless entry option? my 2017 doesn't have keyless entry but i have bought a dummy key which i would like to use. Thanks.
Old 07-24-2023, 10:38 AM
Mavros37
4th Gear
Mavros37's Avatar
Does anyone know if the dummy fob has a battery in it?
Quick Reply: How to Remove the Dummy Key
