LCU-One
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
Yes, you can get an AFR, IIRC. The reference ratio is set in the configuration according to a dropdown menu for fuel choice, IIRC.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
which cost no drachmas
The LCU-One will give you lambda or AFR (which is calculated from lambda). Most engine builders look at lambda and that is what O2 sensors actually read.
The two examples I showed are not from an LCU-One unit, but the data is the same and the alarms would be the same except for the channel names.
Sorry about any confusion I caused.
I simply meant to indicate that if the OP already has a working and trusted AFR/Lambda value-providing system like the LM-2, and it offers an analog output (or two if there are two oxygen sensors) that provides a voltage that corresponds to the AFR/Lambda value, then likely just connecting this system to an AIM input will allow values to be logged and alarms to be established.
AEM and Innovate (LM-2) and perhaps others have products with such outputs and provide the necessary voltage to AFR/Lambda equations or look-up tables in their documentation so you can easily configure these channnels in the AIM software. In my case it took 5 minutes to connect the AEM output wire to one of my EVO4 inputs and to type in the values in RS2 software sensor configuration set up process. One wire to connect and some typing-- all of about 5 mintes.
No benefit of buying the AIM AFR/LAMDA product and eliminating my AEM product that I could justify.
Just an alternative and far less expensive approach if one already has AFR/Lambda HW that they trust and has the appropriate output line and documentation.
And not to put too fine a point on things...
I tried an LM-1 for a while and couldn't get it to work in my application. So I sold it. Innovate had terrible support and they had a bunch of SW "grannies" related to exhaust heat and calibration that I just couldn't deal with.
I bought an AEM unit as did several of my friends and we have used them successfully for years.
Being able to log AFR/Lambda values to match with throttle position and rpm was one of the tertiary reasons I bought the EVO4/Gdash from Peter. I knew my AEM had an appropriate output and documentation so I figured that there was no need to buy AIMS expensive wideband gadget.
To connect the AEM output to the AIM input cost me a sub $0.01 butt splice and a 2" piece of 1/4" diameter black shrink tubing.
I looked around again last Fall at widebands, and there are a lot of choices and plusses and minusses. Along with a range of reported experiences. But as my friends and I trusted our AEM units I stuck with that.
So if you have a system that you trust and use(d) for tuning and/or monitoring, and it has the necessary features and documentation... in my opinion and experience... heck why not use what ya already got.
- MM
- MM
Rennlist Hoonigan
Innovate does give you a table that you can use with their 0-5 volt analog outputs. I've used the Innovate systems without trouble for a bunch of years. I think the LCU-One is a better unit and easier to use if you have a dash.
Not to nit pick, but it was at more than just a butt connector to hookup your system. You either needed an Binder 712 connector at around $10 or a patch cable with the end cut off for $39.
I wish AiM would sell 719 cables with one end unterminated. I've got so many of the unused ends sitting around...
Sorry-- thanks for the correction Matt.
My AIM provider threw in some of the necessary single-ended wires, gratis. Value-added. I am sure that you and others do the same from time to time.
And I hope that you ALL know that we really appreciate the support and evangelism. I think if I had to give ONLY ONE recommendation to a company like AIM, it would not be better documentation or release/rollout execution or SW robustness... it'd be to find a way to reward ya'll for what you have done and continue to do as evangelists. And "y'all" would include folks like the AIM USA staff in CA and VA and Mr. Caddell.
- MM
- MM
Question for you guys with the LCU-One unit, just picked mine up at the track this weekend and there doesn't seem to be any mounting holes, do you guys just fabricate a U bracket or something to mount it?
Basic Site Sponsor
Basic Site Sponsor
Velcro is a brand name that you get at Wal-Mart. I use 3M Dual Lock which is super strong and buy it from Amazon. https://www.amazon.com/3M-Dual-Lock-...sable+fastener
Basic Site Sponsor
Basic Site Sponsor
Hahaha!
