TPS Calibration?
TPS Calibration?
Started to play around with math channels and noticed that the TPS measurement at full throttle is around 75%. Ideally I would like that to be 100%.
I have the sensor setup to AutoCal, would it be better to set it to Calib? Or do I have to create a custom sensor and record all the increments?
How does RS know the scale to use? As it looks like its using the max value for the TPS but on the Brake sensor max reading is 900 something but the scale only goes to 50.
Thanks Jerry, that did it, initially I didn't think so as I was looking at the live measures and then I realized there is a gear/config button next to it and there is where I then could set the min/max.
