AIM MXG/MXS new user notes
#62
Basic Site Sponsor
Basic Site Sponsor
Received 2,797 Likes
Great minds think alike!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#63
Did you follow all of the instructions at http://www.aim-sportline.com/downloa...00_102_eng.pdf
Double check your CAN output in the ECU, then check MXG is setup for the Haltech CAN V2. If those are configured correctly, then it's most likely a wiring problem
Connected to Can V2 and connected properly.
#64
Rennlist Hoonigan
which cost no drachmas
Do you get any GPS connection? It doesn't show as connected on your first photo of the dash.
Also, just to make sure, you have transmitted that config, shown in the photo above, to the MXG, correct?
#67
Basic Site Sponsor
Basic Site Sponsor
#70
Ok gang, I'm having a new issue:
Problem is that my AIM MXG is displaying some rather odd oil temp sensor readings.
My oil temp sensor is the Aim oil/coolant temp sensor (AIM PT100 sensor on RS3), connected to channel 3 of my MXG harness.
Tonight, where air temps in my garage are at about 0.0 degree C, and Coolant temps are sitting right at 12 degrees C ALL on a cold engine, my MXG is reporting my oil temp as -50 degrees C on the dash screens
When the engine is running while out driving today, it seems to sporadically shift between the proper temp reading of the oil and these highly exaggerated readings. Suffice to say, it sets off my programmed alarms relating to oil temp quite frequently when driving down the road, as oil temps can fluctuate from 70 degrees C down to 0 or lower degrees C in a split second.
All of this appeared to start the last time I added engine speed-coolant temp related alarms to the MXG a few days ago. They have nothing to do with oil temp. I have tried disabling the new alarms I added, but no dice.
Firmware on MXG and software on computer are the latest ones from AIM's website.
I have checked underneath the car at the sump, and the sensor is in good condition and plugged in. No damage or moisture penetration at all.
Or is this normal behaviour for the temp sensor with the MXG that I am seeing? I would have expected that on a cold engine, oil temp should read similar to my coolant temp...
Any suggestions?
Thanks in advance
Any suggestions?
Thanks in advance
Last edited by jigga009; 03-12-2017 at 08:45 AM. Reason: clarification of the problem I am having...
#71
Just as an update, in case anyone else is in a similar situation - I deleted all of the displays from RS3 and started with a new one from scratch. Same thing.
I have noticed though that while the engine is running and the oil is gaining heat, it starts to read normally again. When cold, the oil temp still reads something like -95 degrees C, but when the engine is started and allowed to warm up for a bit, the display starts to show more "normal" numbers with time.
From what I can see so far, there are 2 possibilities to explain what I am seeing:
1) the AIM coolant/oil temp sensor (PT100) might only be able to read temperatures from about perhaps 10-20 degrees C and up. Anything lower, and it might appear that AIM has not calibrated RS3 with the proper details to calculate oil temp accurately. Given that one cannot actually see or alter the calibration table for this sensor, it is hard to confirm this from my end.
2) Software bug.
2) Software bug.
#72
Basic Site Sponsor
Basic Site Sponsor
Any suggestions?
Thanks in advance
Any suggestions?
Thanks in advance
#73
The first thing I would do is to go "online" in RS 3 and record the milivolts when cold and as it warms up. You may be correct that the calibration doesn't consider 0 degrees C, but I doubt it. If you get changing mV readings as the car warms up, you could build a custom sensor for the PT100. If you have a wildly fluctuating mV the sensor is bad or you have a bad jumper.
#74
Thanks so much for the suggestions guys... I will look into this
Contact 22 - Hard to find in stores locally, but I will look into it. I'm sure an electronics supply store somewhere would have the stuff.
Interestingly enough, the sensor is only 2-3 months old, and most of that has been sitting in my garage. With that said though, there is always the possibility that it is defective, given what I am seeing. I like the idea of verifying the MV readings on RS3 to see what is going on there.
I'll report back
I'll report back
#75
Rennlist Hoonigan
Good advice so far. The sensor is good to 0C as per http://www.aim-sportline.com/downloa...PT_103_eng.pdf
When I have seen sensors do that before, it's always been a bad connection somewhere. I would check the connections at the harness to patch cable and the patch cable to the sensor. Any contact cleaner would probably help.
