Display/alarm/log canbus + analog in small size
Hey all,
I'm looking for a solution that:
But then as slopes are slippery, why not:
I've printed out 1:1 templates for the MXM and Solo 2 DL and I've decided the MXM is too big, but the Solo 2 DL would fit well off to the side. I believe I could add analog with the Channel Expander or ACC/2. The SLM will not work, but thats ok I guess. If I wanted to run a channel expander and a smarty cam, would I also need a CAN expansion hub? What's the optimal way to support a Solo 2 DL with 4 analog inputs and the potential to add a smartycam later? Any other options I'm missing?
- Displays, logs, and has alarms for CANBUS and Analog input data. (Analog oil temp, oil pressure)
- Small enough to mount to the side of my OEM dash, I dont want a dash replacement
- SLM support is a bonus
- Second CANBUS is a bonus (my car is a swap running two ECUs. hah)
- Get into Aim ecosystem so I can have lap timing w/ GPS and accelerometers
- Have option to add SmartyCam
I have an AIM evo4 and gs dash that I just pulled out of my ta2 car to replace with a bigger display. It will do everything you want, including shift lifhts. PM me if youre interested.
Basically this set up:
https://discoveryparts.com/products/...-display-w-gps
The following 3 users liked this post by claykos:
AIM EVO4 and GS dash is an excellent setup. While not quite the easy button of VBOX it is far more configurable and expandable allowing for custom sensors. The GS is the perfect size providing a lot of information in a small space. AIM does a good job of providing a lot of "how to" videos and you can be lazy like me and ask Peter and Matt.
ProCoach (05-30-2024)
Basic Site Sponsor
Basic Site Sponsor
Received 3,344 Likes
Agree with @RobT 394 , the EVO4S/GS-Dash combo is superb. Compact, great value and powerful enough for 90% of the folks out there. I sold more than a hundred fifty of those when I was a leading AiM dealer.
Some people don't want or need a full size display, I know I don't in my historic cars.
It was my primary personal system for years until I upgraded to the EVO5.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
My only hang up is that it cant do predictive lap timing light in the shift lights or even the external SLM
I’m leaning toward a Solo 2 DL with ACC2. Perfect form factor, can show me predictive lights. Just can’t do alarms or run an SLM. Also so close. Gah
I guess i need to decide between prioritizing lap timing or sensor monitoring. I guess my original criteria was the latter. I also have a Garmin catalyst in the car which is a great visual lap timer but that might go away eventually.
Basic Site Sponsor
Basic Site Sponsor
I think you need to follow your gut, here. If your original priority was alarms, which it should be if you're going to a system like this as opposed to the Catalyst, then DO that.
I find limited screen space a challenge for most drivers, which is why the most intelligent use of it is to highlight what is important as fewer and larger readouts in the display and THEN load up on alarms when critical measures go out of range.
I've crafted lap time gain loss, best lap and other timing measures to light the Alarm LED's on the GS-Dash. I think on the EVO4S, I know on the EVO5. I've found limited value for most drivers on the SLM for other than shift lights.
I highlight my qualy page with a large plus minus best lap value, then let the alarms take over if needed.
As long as you're using the Catalyst, the red/green plus minus is all you need there.
RobT 394 (05-30-2024)
That's how I have my PDM display set up. Top LEDs for RPM, and 2 of the side LEDs for predictive (green only, I hate any "red" light that isn't an emergency), with some alarms that overide if/when.
