AIM Smarty Cam 3 Sport chopped video
I am using a Solo2 DL coupled to a SmartyCam 3 Sport. The setup is installed in a Porsche 996 and unfortunately the ecu channels are extremely sparse. That aside, when I download the video from a track session of 10 laps, the camera is splitting up the laps into individual files, but the laps are incomplete. Furthermore, RPM is not being recorded and speed is in km/hour even though I have set everything to mph.
I am not impressed with this system's ease of use...
Any help/advice is greatly appreciated.
It appears to be working. I have not downloaded any data directly to my computer, but the data is showing up on the video, some of it anyways. As I said, speed is in km/hr, no rpm. Lat and inline acc are there. I set all of the parameters through rs3. Start recording parameters are set to "any" rpm 2500 or speed 30mph.
I am looking at the video with rs3 now and I can see speed in mph on the graph but the speed on the video is km/hr. Each file is only a clip of approx 15-25 seconds with the longest one being just over a minute.
From browsing through all of the forums, I gather there is not much functionality from the ecu for the early (2001) 996 models. I selected the pre loaded bosch ecu in rs3. Do I need to pick up rpm elsewhere?
Rennlist Hoonigan
which cost no drachmas
There isn't much available from that ECU.
When you look at the data, does it start or stop at 2,500 rpm or 30 mph? My guess is that you are losing those parameters and it stops logging. Set them to 500 rpm or 10 mph. Camera set to record 1 minute after stop, power off in 30 minutes. Video units are set in the camera config.
It is not picking up RPM. All of the clips start and stop at speeds over 60mph. I set the speed units to mph on the smarty cam also. Shouldn't I be able to pick up rpm off of the ecu?
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
It's a very good basic package of channels that includes a good throttle pedal channel, RPM, water temp, brake light switch (on/off) and some other temps and pressures. The wire to connect to is below or behind (towards the door opening) the drivers side footwell fuse box. This also works on 2002 and later 986 Boxsters, as well. The connection is a grey/blue twisted pair. The white AiM CAN+ goes to grey, the blue AiM CAN- goes to blue.
The earlier models (1998-2001) are pretty crappy and can only use the OBDII. The RPM and throttle using ECU Make: OBDII, Model: ISO9141-2 is just too slow to give anything but a choppy, slowly refreshed TPS and RPM signal. No brake info, but there is water temp. Just a function of the age and slow communications within the car.
Let us know what you have.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
