Interest in Data Marker/Flag Button
Rennlist Hoonigan
which cost no drachmas
I wanted to gauge the interest in a button that could be tied into an AiM system as a marker button. It would let you use an analog channel as an input so you could put a marker in your data for you to find in analysis. Lots of motorsport steering wheels have these. Pricing would be around $45. I could do a few different colors, any length. Pictured is just for a prototype/sample. The whole mount diameter is 12mm and it's a nice low profile button.
Let me know what people think and I can make them if there is interest. What do people think?
Low profile button with lock nut on the back.
Easy connection to AiM data systems with a custom length on the cable.
kristap (09-01-2022)
I've wanted this for a while. I am in. Ideally I would like to place it on the steering wheel so cabling and connections that would facilitate this would be helpful.
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I have a steering wheel mounted home-made version connected to a RIO and PDM. That even looks like the same push button switches I used.
It's awesome to be able to pull up a f-ton of data and quickly go to the oh-crap or I'm trying something different, moment(s).
Matt Romanowski (07-29-2022)
Rennlist Hoonigan
It allows you to put an easily findable reference mark in the data file. Maybe you are trying 2 different lines through a corner. Click the button once on the straight before that corner for line 1; push it twice for line 2. Then you know, without having to cross reference video or have a great memory, what you did.
The following 2 users liked this post by DTMiller:
Matt Romanowski (07-30-2022),
ProCoach (07-30-2022)
If you have full CAN bus integration and stock steering wheel... you could use the cruise cancel button, if you know what the signal is.
We use this and variations of this in testing...
ProCoach (07-31-2022)
Rennlist Hoonigan
There are a ton of cool tricks if you have full CAN integration. I figure these buttons are great for someone that doesn't have the ability (hardware or software) to do something super trick. This is the easy button for people to put a marker into their data.
Did something similar on my non-CAN bus road car with a standalone ECU to add a marker. Repurposed an OEM momentary/non-latching rocker switch in the center console.
OP one suggestion might be potting that switch. Would give a much more reliable and robust connection, especially given those are soldered joints. For the Otto switch in my pic (same switch as yours except mine is latching ) I used a small section of SCL and partially shrunk it around the base of the switch then used that as a receptacle for the potting compound.
Basic Site Sponsor
Basic Site Sponsor
