Harry's Lap Timer and brake psi?
So longer term I intend to use my trusty AIM Solo with a Smarty Cam attached, but for now I'm using the ever so simple Harry's Lap Timer on my iPhone. For simple lap times it's super easy especially since I bought the app years ago. I am learning that there are OBDII bluetooth connectors available that provide some data. My question is:
Is there a way to get brake psi using Harry's Lap Timer and one of these remote units? It seems it ought to be available since the Porsche Track app captures brake psi.
Thanks to any that can help
Too bad I didn't know about the Porsche Track app when I spec'd my car. It seems like a fun easy option. The video below was supposedly created combining video from an iPhone and the Porsche Track app on CarPlay. Not sure how that works, but it does look interesting.
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
No. The OBDII standard that generic readers (and even AiM's OBDII/CAN protocol) use does not include brake pressure.
PPTA is done through USB to a module in the car that supplies that. No OBDII required.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Sorry for being dense, and I know it's not truly relevant to my initial question, but what is PPTA and can I access that somehow without the Track App?
Basic Site Sponsor
Basic Site Sponsor
Bringing back an old thread . . . .
If brake pressure isn't available via OBDII then I presume throttle data isn't either. How are people using Harry's, Aim, or any other DAQ getting this data then?
Brake pressure is on the canbus and any logger that can tap the canbus can get it if you have the PID.
Brake pressure is also in the EXLAP protocol, which can be accessed via an open source library (some assembly required) or https://www.petreldata.com/product/c...r-for-android/ which is quite decent.
My setup is in here, and I use circuitstorm on a spare android phone. https://rennlist.com/forums/data-acq...n-a-718-a.html
Basic Site Sponsor
Basic Site Sponsor
Shortly thereafter, many (but not all) manufacturers started sending their own proprietary PT CAN info to pins 6 and 14 of the J1979 (OBDII) connector. GM Performance, the later Vipers, some Stellantis, Ferrari and some others provided massive information IF you had the messaging, scaling and offset to “read” the channel info. Some companies like AiM and Racelogic reverse engineered this info, some like Porsche and BMW made their apps the only easy way to read this info FROM THE OBDII PORT.
Now, it’s all over the map. Many companies, including Porsche, are installing gateways, or filtered, one way guardians of the vehicles CANbus. Enterprising hackers have worked out what messaging is there to add to the normally paltry number of channels usually made available.
Bottom line is OBDII is only an attachment point for many of these loggers, and what is available is governed by not only what the manufacturer deems necessary to send to pins 6 and 14, but also the time and effort to reverse engineer what may or may not be there.
Basic Site Sponsor
Basic Site Sponsor
Just no brake info on the standard OBDII info in every car.
No brake info unless a proprietary CAN messaging template (sometimes available via the OBDII connection, sometimes via direct connection to the appropriate twisted pair) is used.
Throttle, engine speed and coolant temp, among a few other less useful measures, are always available through OBDII since 2006 or so, on some before that.
