Aftermarket TPMS System with display?
Hi any reasonably priced thoughts on an aftermarket TPMS system that works on cars with no factory TPMS system?
My car doesn't have TPMS and the Motec version is insanely priced to add it. Looking for a good in the wheel sensor kit with a strong display.
Rennlist Hoonigan
which cost no drachmas
I have a reasonably priced system for 4 wheels and it ties into the MoTeC for display. https://trailbrake.com/tire-tpms/
If you want 3 wheel sets you can go with this https://trailbrake.com/13-wheel-tpms/
Kein_Ersatz (05-15-2022)
tgsmith4845 (04-17-2024)
Thanks.
I used these displays for a while with very good results. Worked well, but you need one TPMS set for each wheel set you use. The most expensive part is installing the TPMS sensors on all your wheels:
Amazon.com: U800 Universal TPMS Tire Pressure Monitoring System Inner/External Sensors Celsius or Fahrenheit Temperature Display PSI or BAR Pressure Display Solar Power (inner-sensor, battery replaceable) : Automotive
I confess some ignorance about physical compatibility of the internal sensor / tire valve with my wheels. Is the interface pretty much standard? I am about to have my wheels rebalanced for the season so I can have the sensors/valves installed then. I believe the shop is very knowledgeable about this (Radial Tire in Silver Spring MD). Paul is the guru there and I am sure he will tell me if they can do it properly.
Thanks again!
I think I am going ahead with the system that Frank recommended, but I did see another system that also looked promising given its batteryless technology and motorsports pedigree (claimed anyway). But I didn't completely follow the installation text - not sure how much in-car wiring is required. Anybody have experience with it?
TPMS Sensor ST9352 (mvpmotorsports.com)
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
That Stack system is nice, but that is the price for ONE sensor in the wheel.
This is the complete kit... https://www.mvpmotorsports.com/stack...-tpms/st9351us
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
steveP911 (01-04-2024)
I have several sets from Cacagoo. They were very cost-effective. The particular (model number) sets I use are now discontinued, but I like them. I prefer the screw on sensors because of how many wheel sets I have. I can swap wheels at the track, swap the sensors over and good to go. If I had one dedicated wheel set, I would prefer the "installed" sensors.
I also run a set on my trailer - the unit in the cab easily picks up the pressure signals from that distance. Towing a car trailer and knowing that you don't have a tire going down is very comforting.
Cliff
Cliff
Basic Site Sponsor
Basic Site Sponsor
https://www.stackltd.com/prod1.html
The UK site here: https://www.stackltd.com/stack_history.html
Colin Harmer and Pegasus are dealers and have stock. I think they were bought out by a bigger company (Autometer) some time ago.
I think I still have a DataPro 2000 CD around somewhere.
Rennlist Hoonigan
Stack was bought out at least 6 years ago and probably more than that. I had talked to Colin back then and systems weren't available and it looked like it was done. They have faded to obscurity since. Though I do like the look of their old analog dashes.
Basic Site Sponsor
Basic Site Sponsor
The reason why Colin still carries spares is because it was a series requirement for Grand Am after 2011 and some folks still use them. A lot of vintage GT and prototypes still use the system and manufacturing is located in Illinois.
Rennlist Hoonigan
That is a great recap of the Stack website, but Colin does not have them listed for sale on his website, JEGS says they are unavailable. Even the Stack page on them is not available through the menus and I don't think the Stack website has been update in 8 years.
ProCoach (01-04-2024)
