Aftermarket TPMS System with display?
Thank you, Frank. You are very helpful guy! If you have used them successfully then that is a good enough reference for me. Pretty fair price too.
I confess some ignorance about physical compatibility of the internal sensor / tire valve with my wheels. Is the interface pretty much standard? I am about to have my wheels rebalanced for the season so I can have the sensors/valves installed then. I believe the shop is very knowledgeable about this (Radial Tire in Silver Spring MD). Paul is the guru there and I am sure he will tell me if they can do it properly.
Thanks again!
Thanks again!
steveP911 (01-07-2024)
I used these displays for a while with very good results. Worked well, but you need one TPMS set for each wheel set you use. The most expensive part is installing the TPMS sensors on all your wheels:
Amazon.com: U800 Universal TPMS Tire Pressure Monitoring System Inner/External Sensors Celsius or Fahrenheit Temperature Display PSI or BAR Pressure Display Solar Power (inner-sensor, battery replaceable) : Automotive
Amazon.com: Tymate TM7 Tire Pressure Monitoring System, Wireless TPMS with 4 External Sensors & 6 Alarm Modes, Colorful Display, Real-time Tire Pressure Monitor System, Ideal for RV SUV MPV Truck Sedan (0-87 PSI) : Automotive
$40. Display plugs into accessory outlet and then you just install the sensor caps on the correct wheels. This system works right away. Checked it out on my truck and its tires. I will have to reset once I install on the UHaul trailer wheels. I will feel much safer, so thanks for the advice.
ProCoach (03-04-2024)
I have tested out the internal sensor TPMS recommended by Frank, and I find it works very well! I carefully set my fronts and rears, then rolled off (it takes motion to reset the values) - display values were exactly the same as my set pressures. Got about 3 psi rise during yesterday's drive to Tech Inspection. Thank you, Frank!
I also tested out the external sensor TPMS mentioned above (Tymate TM7) on my truck, using the truck tires, and found it works great. I will reset the HI/LO alarms once I move the sensors to the trailer (Thursday). I will feel much more comfortable with that. Thank you, chudson.
Always appreciate the great advice!!
The following 2 users liked this post by Frank 993 C4S:
steveP911 (03-19-2024),
tgsmith4845 (04-17-2024)
The external TPMS in my truck worked great and really added to my peace of mind trailering a UHaul. Nice bright display that plugs in the accessory outlet.
Had issues with the internal TMPS on my track car. I think the tire shop did not follow the torque guidelines and I had a stem leaker on day 1. I could see the leak easily once I sprayed with my non-ammonia window cleaner (very foamy and works great). I tightened the stem (built in hex) and checked/tightened all of the others. Over the course of the weekend two more leaked. One time really quickly coming out of grid. My car is now at the shop for something else, so I asked them to check it out. They may have to unmount the tires. Pretty annoying when your TPMS causes leaks. And the display is not bright enough, as I was warned. I may have to make a little house over it.
I know some have said that external TMPS sensors screwed to the valve stems are problematic at high speeds. Maybe during initial high G braking? Or is that not a worry?
Thanks.
Thanks.
Well, I am throwing in the towel on the internal TPMS in my track car. Too hard to see the psi display, it keeps beeping at me even though I think I have the min/max settings right and I am not below or above them. Then one of the sensors got broken during tire mounting. Finally, today as I was refilling them to get then to street pressures, one of the stem checks got stuck. Had to pry it up with a pointed tool to seat and seal. No coincidence that tire required a few psi bump up after every session this weekend. Maybe it's me but they ended being a PITA so they are coming out and being replaced with sturdy motorsports valves.
Still love the trailer external TPMS setup.
ProCoach (04-16-2024)
