Mychron 5 2T/ SmartyCam V2
Hi, I’ve been running this set up (water temp only) along with an exp box for brake/throttle sensors.
I decided to fit an egt sensor & it’s showing up on the Mychron along with the water temp all fine.
I’ve noticed though, the egt which I set up in the Smartycam config in RS3 is not showing a reading on the SmartyCam live view or video?
silly question perhaps but kart sitting on the stand my Mychron is reading both temps at water 8*c & egt 10*c, Smartycam has nothing showing for egt on live view & I’m just wondering why it’s not showing the egt reading?
I’m not in a position to fire her up yet but do we reckon this might be all that’s required to get a reading at the Smartycam?
thanks in advance.
thanks in advance.
Rennlist Hoonigan
which cost no drachmas
I'm not too strong with Mychron units. If you have set the EGT correctly in the SCHD overlay, I believe it should be there. Maybe give the guys a call and I'm sure they can help. East Coast is 540.342.9680
Matt Romanowski (03-18-2022)
I’ve removed the exp box from the system & now I just have the M5 (water/egt sensors) & SCHD lead connected to it.
in the M5 live measures the egt is showing as temp 1? , the water is indeed the water temp.
in the SC live measures, the water temp is there but no egt or temp 1 as it showed in the M5 live measures?
the config all looks ok with the temps labelled as water & egt.
Any ideas?
could it be the lead from the SC to the M5?
thanks in advance
