PRI Data Report (including AiM Info)
#31
jigga009 -To be completely honest, it sounds like you are having some odd problems that might be hard to produce on other computers. I had a little trouble following everything, but I have not found RS3 to be unstable and certainly not have multiple open CAN configs make anything crash. I have also not had configs change on their own.
I'm willing to try and help you out with this. Shoot me an email - matt@trailbrake.com and lets see what we can figure out. If you have some odd crashes, we'll get Italy involved and see what we can do.
When I sent my MXG configuration files as well as my ECU map to Link's Technical support for diagnosis, they confirmed that they had run into a lot of the issues I have seen, and pretty much echoed ProCoach's sentiments. The advice from the tech support agent I spoke to was not to try to avoid using the canbus gain and offset features on RS3, and instead to try to do as much of that as possible from the ECU side, and then create a math channel on the AiM side to perform any remaining conversion that is required. While this works for the most part as a quick and dirty workaround, it isn't a true solution given how many math channels could potentially be needed to convert the affected parameters that are coming from the ECU.
Are you using manufacturer-supplied canbus streams or are you writing custom streams from scratch?
Unfortunately, I am still unable to display differential fuel pressure from my ECU because the figures being displayed on RS3 appear to have some kind of offset, gain, (or both) applied to it that the AiM side (even though gain is set to 1.0 and offset = 0 on the AiM side). As a result, I'm not even sure as to how to begin structuring a math channel to correct the numbers on RS3.
I guess I will try reinstalling the software and firmware, as well as rewriting my config files from scratch in the hopes of gaining some stability.
#32
Rennlist Hoonigan
which cost no drachmas
Matt, thanks for the response. I'm appreciative. Do you have access to a Link standalone ECU by any chance? I'm not sure if it would be possible to replicate things unless you had the ECU map (which also includes the "transmit" canbus data stream).
I'd rather take this to email and get the AiM people who can work on it involved. If we can give them the specifics of the Link ECU, channels, AiM dash model, FW, etc., then we can work through things and get it right. Matt@TrailBrake.com
#33
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
Then, the most expedient thing would be to reach out to AIM Sports directly, specifically Robbie Yeoman, get the .dbc from Link (they’ll give it to you) and work with him to have that supplied .dbc imported into an .xc1.
This has worked for me in the past with a number of ECU’s in purpose built race cars, Cosworth and Marelli. There’s no “translation” or maths required then. Very clean.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#34
Rennlist Hoonigan
I would do the last sentience first.
The dbc import is not hard and something I do a ton. It's something any astute dealer can do. It's also not always the best way.
#35
Basic Site Sponsor
Basic Site Sponsor
The staff at AiM Sports is a huge resource, certainly ready, willing and able to help.
This is a relatively common aftermarket ECU, and it turns out there’s already organizational knowledge within the group.
The .dbc import is indeed pretty simple. But, if they’ve offered to help, why not take advantage of it?
#36
Rennlist Hoonigan
Jigga009 - shot you a PM yesterday. Happy to help and get the right people involved to solve your problems. Just let me know.
#37
#38
Matt. Any word on CANbus channel limits?
Slakker (01-02-2022)
#40
Basic Site Sponsor
Basic Site Sponsor
Nicest thing is that there is not the current SmartyCam sampling rate restriction in the upper range of the new cameras.
So, usable information can be displayed and calculated in RS3A beta, not just a topical review.
They made it a point at PRI to state that the goal of the integral bridges in the upper range of the new cameras could be to use the cameras as standalone loggers, as well as cameras. Good stuff!
#41
Rennlist Hoonigan
#42
Basic Site Sponsor
Basic Site Sponsor
And you know nothing of my communications about with AiM principals and employees.
You’re not the sole font of AiM information, much as you’d like to come off that way.
#43
Rennlist Hoonigan
And don't forget to pickup milk on the way home from the coast.
#44
Basic Site Sponsor
Basic Site Sponsor
The data sheet (released a few weeks after PRI) shows that the dual camera GP3 includes an Ethernet bulkhead connection off the main harness (22pin Autosport) from the unit itself. Multiple CANs, too.
That and the massive storage capacity shows that there is really good headroom to grow here.
