Getting into the data with Porsche Track Precision
So I have finally dialed in a good template in racerender that I can use with Porsche Track Precision and my GT4. I have data for wheel slip and understeer/oversteer visualised, but the problem is these are somewhat arbitrary units of measure, and I don't know what actually constitutes an optimal slip angle and when it has gone too far.
I am using the OEM Michelin Cup 2 tyres, and am keen to know what their optimal slip is in traction zones and yaw through corners? Some meaning behind the understeer and oversteer numbers would be good also.
If I can quantify what these optimal slip angles are on these tyres I will be able to add the ideal numbers to my data overlay and be able to do a better job of identifying areas where I am overdriving/underdriving and make better choices with setup and alignment changes. So far I am doing most of it by feel but if I can shortcut that with some solid numbers then that will help a lot. I think this is how PTP defines its "Drive to your limit" measure but I don't know how that number is actually derived so it's not very useful to me.
Here's a video of my latest hot lap. If anyone knows what the numbers coming out of PTP actually mean then please share so we can understand it a bit better!
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
Nice
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Hi! Any chance you're willing to share your race render template? I struggled to create one but I was rushing. Couldn't even find room to define all the custom parameters.
I'd have to take a look at the data to try and interpret some of these values. Generally speaking, understeer and oversteer are defined in terms of front:rear slip angle ratios, > 1 is understeer and < 1 is oversteer. I don't know if that's the definition they're using in the app.
