Merging Data Files
Rennlist Hoonigan
which cost no drachmas
Matt - quick update. First, thank you for all of your help with resolving this issue. Second, after sending a bunch of files to aim support, they think they found the issue. The trigger RPM to record was set too high. I thought that once triggered, it would record until the car is restarted. Because, IIRC, the setting is for when to start recording, not when to stop. But evidently, if the RPMs fall below that number, even if at 100MPH, then, boom, restart of data collection.
I ran a race a couple of weeks ago and I played around with the fan switch again to see if it would trigger the problem - it didn't. So, running another race this weekend. Hopefully, won't happen again.
Again, thanks for your help. I really do appreciate it.
Mistakes from the parameter settings are not uncommon and I think AiM need to do a better job on explaining it's start AND stop. There was someone on FB just this weekend that had the same problem.
No problem and I'm glad you got it worked out. I had actually followed up with the guys and they had thought you had it solved. They are really top notch and make my job easy!
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
Been on the list for a few years. MoTeC and VBOX completely customizable start/stop parameters.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Different start / stop params just seems so obvious.
But AiM should at least fix the wording to make it clear what the parameter actually does.
DTMiller (06-15-2022)
