AIM Solo 2 DL in 718 GT4
Hello,
Got recently 718 GT4 and tried today to sync AIM Solo 2 DL to it.
These are ECU's the software shows me - I've tried 2 marked - didn't work.
Will really appreciate help on this
Thanks, Gennady
Thanks, Gennady
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
For the street car, 991_911 to the correct twisted pair.
For the race car, the 718 GT4 CS to the four pin DT CAN connector in the passenger side door sill.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Thx for the replies !!!
This a street car.
I've connected it to OBD port - not enough?
This a street car.
Which one?
991-981-OBDII?
992OBDII?
with or without "resistor" option checked?
Or some generic option not Porsche related?
991-981-OBDII?
992OBDII?
Croc999 (07-14-2020)
Thanks!!!
It worked.
Will see what data it actually records
It worked.
Basic Site Sponsor
Basic Site Sponsor
Great to hear !!!!
At idle it didn't show me IAT.
Will see if it will show it after some driving.
Fuel level does work - i like seeing exact number at Solo
I have a 2021 718 GT4 (street version not CS) and trying to connect via the OBD-II port and I have not been been successful (after countless attempt).
ECU Stream is set to OBD_II - CANbus but no live reading of RMP. I am using RaceStudio3 (64bit) 3.35.01 to transfer/update the setting to the AiM Solo 2 DL unit.
Here are screen shots of my settings:
Basic Site Sponsor
Basic Site Sponsor
Uncheck the RPM measure under the Channels tab. That will help.
OBDII/CAN sucks for the 718 GT4.
991_911 is much better, but you have to connect directly to the wiring harness near the fuse box. If you want a premade cable that installs without tools, let me know.
You could try this, too. I've confirmed that many of the same CAN ID's are the same from the 981 GT4.
Best, Peter
Best, Peter
SonicSound (04-02-2021)
Best, Peter
Best, Peter
thanks for you input.
Rennlist Hoonigan
which cost no drachmas
In my experience, the RPM analog signal does not create any problems when on a CAN connection as well.
Yes, the CAN option goes straight to the cars wiring. Generally not hard.
If the ODII isn't working, double check the pins where it connects to the S2DL. I would also see if you can get another OBDII cable to check that you don't have a bad one or something odd going on. Since it's Friday night you won't have anything in time for your event, so you'll have to work with what you have.
SonicSound (04-03-2021)
Do you think there is any chance it’s the unit? I am going to check around the paddock at VIR this week to see if I can borrow an OBD-II cable and units to trouble shoot. This has been very frustrating, the last 6 weeks trying to figure it out. Again thanks for your input.
I do have the CAN cable. Is it difficult to wire in the 718 GT4?
