Solo 2 DL randomly rebooting during sessions
I was at the track yesterday and noticed an odd behavior with my Solo 2 DL. The device would reboot itself randomly during my sessions. The attached photo shows where the device is mounted. I recently moved the mounting location from the left side windshield to a hard and more permanent mount shown in the image. This location is more in my line of sight.
Does anyone know if the mounting location shown in the attached image too low? Or any other ideas on why the device might be randomly rebooting. I've experienced this once before at Sonoma where the device was mounted on the left side windshield. So I don't think the problem is the location. The device was fully charged the day before my event and is also getting power from the car. It is also upgraded to the latest firmware.
When I experienced this previously (at Sonoma), I switched back to my old Solo DL and it had no problems whatsoever.
Thanks,
Brian
Thanks,
Brian
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
The position of the unit is fine. Could be a battery issue, a loose connection to car information, if it's OBDII one of the pins in the car receptacle could be pushed out, but I'd send it in to AiM Sports in Lake Elsinore and have them check it out.
Position of the unit is very good.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Hi Matt,
When this happens, I do not get any data files on the solo 2 dl device. I do have video with the data overlaid on my SmartyCam, but the laptimes are incoherent; there is no time for the current lap or best lap, the current lap time just runs for the duration of session before solo 2 unit reboots itself.
I've tried calling the AiM office in Lake Elsinore, but no answer, I'll try again tomorrow.
Brian
Brian
Rennlist Hoonigan
which cost no drachmas
Check the recording parameters then. I've had this where the device isn't recording, so it turns off and then is immediately woken because of the power/CAN connection.
Basic Site Sponsor
Basic Site Sponsor
Since the default start parameters are now above 500 RPM from the OBDII and above 6 mph in GPS speed, this should not be the issue, once on track.
I spoke to Bryc and Cameron from the East Coast AIM office today and they suggested sending it in.
Mine did the same thing. Was extremely annoying. I even sent it back to AIM and the unit checked out just fine.
Matt had me change the "Start Data Recording" parameter to a "Custom Condition" of "GPSSpeed Greater than 20mph" and DE-SELECT "Standard Conditions" under "Start Data Recording". Problem was solved immediately and forever. Does not randomly reboot itself any longer and works perfectly.
I would try that first before sending it in. If that doesn't work then there is some other issue or a loose connection somewhere.
Anthony
Anthony
Basic Site Sponsor
Basic Site Sponsor
Anthony, that was back when the “Standard Conditions” listed “Speed (not GPS) above 6 mph” as the default.
There were so many support requests when the units wouldn’t log that a new firmware/software package was hurriedly released that changed default “Standard Conditions” to “Speed (including GPS)” as a trigger.
I don’t know how old the OP’s Solo 2 DL is, but the issue that caused your problem was attended to after Matt, me, MANY other dealers and AiM Sports US alerted the Italian company of this issue, the one that you had.
Certainly worth a check before sending it in.
Thanks everyone for the suggestions. I did check the "start recording" settings last evening, and it was in fact set to use a custom parameter. The unit is ~10-11 months old. I set the recording parameter back to the default setting. I'll be back at Laguna Seca next weekend and will see if the setting makes any difference.
Basic Site Sponsor
Basic Site Sponsor
Depending on the firmware and configuration software versions, it’s the default setting that could be causing the problem, especially if the default speed says (not GPS).
bml376 (10-11-2019)
I don’t know about most people, but I always set it up Custom parameter using “Any” and RPM above 500, along with GPS Speed above 18 mph.
Rennlist Hoonigan
Awesome! I'm glad we got it before you sent it in and they didn't find anything. Enjoy the S2DL and post up when you have more data questions.
