Aim CAN cable 7-pin vs 8-pin
Hi guys,
Can anyone provide me details on the differences between the 7-pin CAN cable connector that the original Solo DL uses, and the 8-pin cable that the Solo 2 DL uses? I had the original Solo DL hardwired into the CAN harness on my 987.1 car, and have just purchased a Solo 2 DL and I notice that its CAN cable receiver is 8-pin versus the original solo's 7-pin. The cable that came with the Solo 2 DL is 7-pin, just like the original Solo DL. I am hoping I don't have to remove the original cable that I've soldered in and redo the job with the 8-pin cable (which I don't even have).
I tried searching online & here in the Data Acq sub forum, but no luck.
Cheers
Cheers
Rennlist Hoonigan
which cost no drachmas
The 8th pin (center) on the new S2DL is the RPM input. The old cable will work fine with a S2DL, but obvoiusly you can't put the 8 pin wire in the 7 connector on an older Solo DL.
Will RPM still come through the CAN line using the old 7-pin connector, same as the original Solo DL? Or do I need to buy the 8-pin cable to get RPM now? Sorry, haven't tested this in the car yet.
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
Hi guys,
Cheers
Cheers
8-pin only for "vintage" cars!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
