SOLO2 DL generates small partial TESTs
Hi all,
Just joined the list and this is my first posting.
I have had SOLO2 DL for more than a year now and I have had this issue ever since.
The issue is, I get many small partial TESTs. These small TESTs only contain like 30% of a lap.
The other 70% of the lap is in next TEST. I have tried many different locations in the windshield for better GPS reception.
My questions are
1) Why is this happening and how can I avoid this?
2) Can I merge TESTs?
Jake
My questions are
Jake
Rennlist Hoonigan
which cost no drachmas
Starting with question 2, you can download the test together and then do a GPS Lap Insert and it should put them together.
What starting conditions do you have for the test. What track? Is this happening only at one track or all tracks you visit? What is the GPS accuracy from the tests that show this?
I have some TESTs which is only like 16 second long and just one lap. I think GPS Lap insert can merge many laps within one TEST. I would like to merge laps in multiple TESTs.
My start condition is "when GPS speed is more than 60km/h", do you recommend any other condition ?
The track is in Korea and it is Inje speedium. It is a beautiful track in mountains(high altitude) and the altitude delta with the course is like 40 meters.(Many ups and downs)
This problem happens more in this track. GPS reception says GOOD and 6~8 satellites.
Jake
Rennlist Hoonigan
An S2DL should have 10+ satellites, 6-8 is kind of low.
If you download the multiple files to one session,I believe you can do the lap insert to combine session.
