Solo2DL Issues....need some help
Hi All ....I'm having some issues with my Solo2 DL or, more accurately, my issues in understanding how to use it.
Below image is what the manual shows giving me the option to choose triggering from RPM or Speed
This same page on my device has no Memo Trigger option. It has the same Predictive Reference option as the manual, but no Memo Trigger option, just an Auto Off timer.
What am I missing? Does my device not have the correct firmware / software version?
Matt R or others -- any guidance?
Thanks in advance.
Thanks in advance.
Rennlist Hoonigan
which cost no drachmas
I'll be honest that I never looked on the device for that screen. I set it in RS3. See the attached imagine of the parameters tab. If you open RS3, receive the config in your device and then you can open it and change the starting conditions to whatever you want. I normally use RPM OR Speed if it's a track only car.
