AIM added Brake Pressure for 987.1 to the ECU line
FYI
Better late than never, for folks racing Gen 1 Caymans with an AIM system and without an analog sensor. I did not see this posted elsewhere.
Many of us already have analog sensors installed and a brake pressure sensor channel has been available on the ODB-2 port for quite some time but, in the January 2019 Bosch 997 - GT3 (2.00.01) ECU update several 987.1 specific channels were added and/or renamed, including a proper brake pressure channel, to differentiate them from the 997 versions. Why, they don't have specific files for each car, is beyond me, even if they are mostly the same. Anyway, I discovered this on the weekend, when I reloaded the "latest" channel map to solve a weird problem of my gear indicator and rev lights not appearing on my dash after an unrelated config change. Problem solved but, several profiles broke and when I went to look, I discovered the renaming and the new channels. The ECU brake channel looks a little smoother than the analog brake sensor. Not sure if that is smoothing or, sampling differences yet.
Tim
Tim
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
It’s a good thing!
The new map works great on my MXS but, I can only see the old map in RS2 when I try to update a SOLO. Can you update the available maps in RS2? Most of my experience is in RS3.
Thanks, Tim
Thanks, Tim
Rennlist Hoonigan
which cost no drachmas
FYI
Tim
Tim
Basic Site Sponsor
Basic Site Sponsor
0-100 sounds like your brake pressure is in bar (1 bar equals 14.7 psi), which sounds right.
