SOLO 2 DL Wired into....
....my 2004 GT3 CAN bus system, by my Van Nuys AiM/Motec, etc. Guru, and NO, I won't tell you who he is; I want his services all to m myself....in addition to all sorts of data saved in the SOLO 2 DL for future review on Race Studio #. Another plus, once wired into the CAN bus system, 12V power is provided for charging the AiM SOLO 2 DL internal battery when the ignition is on. I also have a "loaner" SmartyCam,
As you can see on the video display:
The fun part of the drive as seen in the video, was driving with every marque you can think of: TESLA, BMW, Mustang...a Porsche or two.
Oh well, back to Laguna Seca in a few weeks with PCA GGR for DE, and in August with POC for a 2 day Time Trial.
- Speed
- RPM
- Accelerator pressure but NO brake pressure, need to take another approach to get this done, Coach Krause has solved this for me (See below).
- Gear selection
- Cabin audio....no swearing from me.
OMG
Did a track day st Laguna Seca with Speed Ventures, great group with good drivers, saw no off track excursions or incidents of any sort.
First time out with my AiM SOLO 2 wired into the 2004 GT3 CAN bus system. As usual the Predictive Timing feature on the AiM was very helpful.
The over the top top fun thing was watching the video produced by the “borrowed” SmartyCam. I spent an hour with David Ferguson, my local AiM dealer (now that I am back in Paso Robles), looking at the video and the data from the SOLO 2 DL. He is a nationally ranked SCCA Prototype driver, which gives him huge credibility IMHO.
In the past I have been reviewing my data, it was always informative in a one dimensional sort of way. But with the above AiM system hard wired in place,
the the impact is so much greater when accompanied by video. Throttle position, breaking effort and long/lat G forces.....what can I say that hasn’t been said. This is a totally affordable system, less than $2,000. Our AiM dealers on the Forum will hook you up. My only regret, I didn’t do this earlier in my driving career, the SmartyCam that is.
Basic Site Sponsor
Basic Site Sponsor
Received 2,827 Likes
Yes, braking effort in the 2004 996 GT3. A little too early to get brake pressure from the car itself.
Video is SO important. It influences driver performance in ways unseen looking only at the data. Car position, heading, traffic, the influence of the curbs, track edges and, of course, the ability to see head and hand movements at the appropriate time, place, speed and amplitude.
You are fortunate to have Dave and Ellen as a local resource.
The complete setup for your car, with the latest hardware releases, cables and mounts, is $1778 from me.
Since the Solo DL (now the Solo 2 DL) and SmartyCam combination became available seven or eight years ago, I’ve sold more than four hundred pair, mostly for Porsche cars.
Glad to hear you’re back on track!
Sage like advice ...
From Peter, and don’t forget to see if Speed Secrets has a Virtual Track Walk for your local track, mine is Laguna Seca.....a virtual Track Walk is available , and I bought it and have watched it many times, and will again many times more,
Prep with the Track Walk and post track, review data and video...that’s my new MO.
Rennlist Hoonigan
which cost no drachmas
It is a powerful combo. I'm glad I was able.tonhelp you our getting this going and your in great hands with David. Keep reporting back!
Brake Pressure.
Peter writes, "Yes, braking effort in the 2004 996 GT3. A little too early to get brake pressure from the car itself." As I was looking at one of the videos, I noticed the brake indicator was not functioning. Is this feature available from SOLO 2 DL hooked into the the CAN bus system? I am thinking it's not and I am going to need a brake pressure sensor. Am I on the right track?
Basic Site Sponsor
Basic Site Sponsor
But, in your car, it is possible to add brake on/off, which is the brake light switch signal, over the CAN to the Solo 2 DL.
To make this work on your car and the SmartyCam, you need to put into the SmartyCam stream (in the S2DL configuration) “brake switch” from the car in the Brake Position Field in the SmartyCam stream. If it does not show up, check the lower left box in the stream field to “Enable all channels.” Then, save and transmit the changes to your Solo 2DL. It will now send the brake on/off information from the car to the SmartyCam.
To show it on the SmartyCam, open the SmartyCam configuration and select the red bar. Instead of brake pressure in the channel field (which it doesn’t get from the car, hence isn’t working), Select Brake Position. Save, then transmit the changes to the SmartyCam.
Done!
Martin S. (07-04-2019)
The info below is priceless...thanks Coach! I bought the AiM SOLO2 DL, but intended to have it set up locally.....need to have a local resource in case there is a technical problem/question.
Yes, your car is a little too early for brake pressure to the S2DL. It is not possible to add an analog brake pressure sensor to your Solo 2 DL, your dealer should have told you that! Or at least set it up correctly for your car!
Done!
Done!
ProCoach (07-04-2019)
If I buy a solo 2 dl / smartycam combo, does the cable from the solo 2 dl charge the smartycam? Or does the smartycam need separate power? I've been looking through the setup manual and it has lots of room for improvement.
Basic Site Sponsor
Basic Site Sponsor
Rennlist Hoonigan
Like Peter, I have Rennlist discounts and units in stock. I get fantastic FesEx rated and ship everyday.
Basic Site Sponsor
Basic Site Sponsor
I prefer power fed by switched ignition power,
but that’s my experience.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
I think my track record on support to my customers and all AiM users is pretty solid. It's in my signature along with my my constant offer for folks to ring my cell when they have a problem. For those that haven't seen it, it's 603-674-3250. I'm Eastern Standard Time. I already helped 2 people this evening.
