Aim Solo DL tracks
Aim Solo DL tracks
2 part question:
1. If I have an Aim SOLO DL hooked to a Smarty Cam HD. If I go to a track that has the map pre-loaded into Smarty Cam, but NOT the Solo DL. Will it automatically start logging and recording?
2. I can not get the SOLO DL to work with Race Studio 3, so I see I must use GPS Manager to load tracks onto SOLO DL. How do I get a map from Race Studio 3 to GPS manager (file types are different)? If I can not, where is a bigger database of tracks for GPS Manager?
Thanks for your help.
Rennlist Hoonigan
which cost no drachmas
2 part question:
The original Solo DL uses RS2 for config and GPS manager for the tracks. The SCHD uses RS3. If you have the track coordinates, you can make a new track in GPS Manager (or vice versa).
Rennlist Hoonigan
It's a .gpk file in your data folder (default is C:\AIM_SPORT\RaceStudio2\DATA) Select a session that has the right track shape and you're good to go.
