Aim solo DL. Can bus or OBD2?
#31
Basic Site Sponsor
Basic Site Sponsor
Received 3,346 Likes
The refresh rate (new info sent), as well as information from the ECU to the cluster and other ECM's that is not needed for diagnostic or inspection (state inspection) purposes are included in the Powertrain CAN (997_GT3) listed above. Typically, most European cars offer more capability through direct CAN interface than the abbreviated information present at the OBDII port. Audi/VW/Mini/BMW and others don't even have information present at the OBDII.
There are some manufacturers (relatively recently) who offer full CAN info present at the OBDII port. Ferrari, Chevrolet Performance, even the Viper has a tremendous amount of info available. It's the makers...
Here is my go-to for AiM connectivity: https://www.aim-sportline.com/downlo...II_eng_118.pdf
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#32
#33
Rennlist Hoonigan
which cost no drachmas
Correct. It's not uncommon for a car to have 5 or more different CANbuses, so they don't all have the same info. What you get at the OBDII is often different than the chassis, drivetrain, or engine bus.
#34
Do you know where I can find a CAN bus on a 997.2 GT3 RS with the maximum amount of information?
#35
Nowadays as OEMs are moving towards levels of autonomy or even just increased complexity/electrification, gateway ECUs are being built with higher and higher levels of security such that you can’t get any information front the CAN bus unless you physically hack into each particular bus before the gateway receives and redirects each message. So you’re forced to only have the SID$22 information at the OBDII port. I’m guessing this is what you’re running into
#36
Basic Site Sponsor
Basic Site Sponsor
SirLapsaLot, OEM's are now considering encrypting the streams for security purposes. I know FCA and Nissan have taken steps...
#37
Basic Site Sponsor
Basic Site Sponsor
A guide I supply for users and installers of equipment I sell in the attachment.
It is EXTREMELY important to connect to a CAN network that the device is programmed or configured to receive. Introducing spurious information on a CAN or connecting a device not correctly configured can cause the vehicle to become inoperative, show MILs and trigger codes.
These directions are SPECIFICALLY for the AiM 997 GT3 driver (configuration) file on AiM devices and for VBOX devices with the appropriate CAN .REF loaded and have been successfully used since 2010.
cbracerx (12-20-2021)
#38
#39
So yes, a device oin the CANbus (or OBD) can cause problems.
#40
#41
Rennlist Hoonigan
I've had this trouble on some motorcycles. It will end up being an industry problem, but most likely part of a larger issue like farmers/John Deere.
#42
Basic Site Sponsor
Basic Site Sponsor
#43
It's funny you mention FCA ProCoach, as I believe some of the CAN bus encryption was sparked by them. It was surely on the table for quite a while before, however a year or two ago I believe it was a couple newer Jeep's were remotely hacked through the infotainment system. So I believe that lit a fire under many OEM's to finish their cyber security development and start applying it to new models.
#44
Basic Site Sponsor
Basic Site Sponsor
Have a few friends in testing and validation there, plus an Alfa Romeo connection.
#45
Digging this one up again, as it already has some very valuable responses... I have just ordered the AiM Solo 2 DL and will be using it in my 2004 996 RS, after speaking to the local dealer prior to ordering, they were confident their OBD 2 would communicate basic information to the unit (I had already read this thread, hence I called to ask)
According to the instructions this is available channels via OBD2, since its been nearly 2 years on the last response, hoping the below is accurate, is anyone running the aforementioned setup in an 04 GT3?
