AIM SOLO DL Help with CAN connection, 987.2 Spyder
This has got me stumped... I've searched through a ton of threads and thought I had this right... https://rennlist.com/forums/racing-a...-cayman-s.html, https://rennlist.com/forums/racing-a...-399-a-16.html, https://rennlist.com/forums/data-acq...marty-cam.html, https://rennlist.com/forums/racing-a...-399-a-16.html
I've tapped into both pairs of yellow/white, black/white (yes - there are two pairs in one bundle exactly the same color...), not getting any type of data. I've tried two different configurations of the ECU - the Siemens that Aim suggests, and the 991_911 that I saw suggested in one of the forum posts when connecting directly to the twisted pair.
Getting no type of data on the Aim at all, just the standard menu. I've double-checked that I transmitted data, checked that the Aim is getting power from the add-a-fuse, really stumped.
So a couple questions...
1) If I am getting data, and the AIM has the right ECU config - I should be seeing the option for "Custom" in the display settings on the Aim - is that correct? Or is there some bone-headed thing I need to do in order to see that? Is there anything else I need to do in the config menu to be able see data like Oil Temp?
2) For a 987.2 Spyder, connected to the twisted pairs, can someone guide me on which ECU I should be using? I thought it would be Porsche manuf, Siemens ECU based on the Aim documentation, although that specifies a connection to the actual ECU, vs. the CAN
3) For the twisted pair color - am I on the right colors? It seems like it based on this post: https://rennlist.com/forums/data-acq...r-987-2-a.html
Thanks - what should have been a pretty straight-forward connection has turned into a frustrating afternoon.
Basic Site Sponsor
Basic Site Sponsor
Received 3,347 Likes
You are correct on the colors. CAN+ (white with AiM, blue with VBOX, white with MoTeC) to yellow/white, CAN- (blue with AiM, white with VBOX, green with MoTeC) to black/white. Just did one at Murry.
Siemens is the correct ECU setting for the AiM configuration. Check to see your pins aren’t bent at the Solo.
Basic Site Sponsor
Basic Site Sponsor
Yes. The purpose of “sending” the configuration to the Solo DL is to tell it what to “listen” for. Perhaps you’re not doing the last step, which is to Transmit the config to the logger?
Thanks - I transmitted it, tried both ECU's, I even did a "receive" after transmitting to verify that it went through to make sure it was on there. Not sure what the issue was - although the battery low showed up late in the entire process so I charged it overnight and had at it again this morning. Did the config again this morning and this time it worked!
So I can verify for the 987.2 Spyder that one of the yellow/white, black/white pairs worked (there are two pairs same color), and that the Siemens ECU was the correct one. Reading everything now!
Basic Site Sponsor
Basic Site Sponsor
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
