Taking power from SCHD2
I continue to experiment with audio inputs on the SCHD2 and have an idea that will require 12V power.
However, I want to minimize all possibility of ground loops and as such would love to use the same power and ground
supplying the SCHD2 (and SoloDL). One possibility is to run a separate power cable from the same point in the fuse box.
Another, cleaner method is to take power from the +Vb and Gnd pins of the 712 GPS connector on the back of the SCHD2.
I will be using a very low current audio circuit and can certainly fuse it with a very low amp fuse (say 1A).
Thoughts? Issues?
I already ordered a male binder 712 4 pin from Newark.
DB
Thoughts? Issues?
DB
Rennlist Hoonigan
which cost no drachmas
I would expect that to work. I don't remember how many amps the dash can supply. The dash provided 12v is loosely regulated if that matters.
Basic Site Sponsor
Basic Site Sponsor
Received 2,836 Likes
Wouldn’t recommend that if you can get it from the fuse box. 1 amp is well beyond the capacity to deliver (or the draw from a) GPs antenna power. The board is small...
Is there someone at AIM I could ask?
I called AIM in VA. They did not have the exact spec of the port, but the GPS unit requires 1-2amps so they believe that port can supply at least that much power.
I don't intend to consume more than a few hundred ma max, so I should be ok.
I'll use a 1A fast blow fuse to be careful.
DB
DB
Basic Site Sponsor
Basic Site Sponsor
DB
DB
I think we're talking mA, but go ahead and try it. I just don't know what your device draw is compared to the GPS-08, which is certainly not 1-2 AMPS...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
FAIL!
I did get power from the pins on the GPS connector.
Unfortunately, it was about 3V, not 12.
I will need to run a separate power wire back to the fuse box.
Good news is my audio setup seems to be working and noise free.
It front ends the SCHD2 with an exhaust mic, cabin mic and extra input for the intercom.
That plus a DSP for some EQ and compression.
DB
DB
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Still don’t think it’s a good idea.
