Brake Bias/ABS/AIM Pressure Sensors
Is this possible, highly unlikely, or just stupid:
My thought is to use brake pressure sensors to detect when ABS is activated and use that as a tool to dial in brake bias adjustments. I'm guessing/assuming the brake pedal pulsing that driver feels when ABS activates is a pressure change in one or both the brake lines from the master cylinder. If I can capture that change with my MXL2 I might be able to "see" on which end of car the brakes are locking first.
In my case (944S2/SP3) I have a brake pressure sensor for the front brakes and one for the rears. I have a bias adjuster "in front" of the rear sensor so it should record the modified pressures. If (big if) I sample fast enough (100Hz?, 500Hz?) is the AIM pressure sensor fast enough to capture the pressure spikes caused by the ABS activating on one end or the other?
Thoughts? Is there a better way to do this?
Thanks,
Greg
Thanks,
Greg
Basic Site Sponsor
Basic Site Sponsor
Received 2,833 Likes
Thanks,
Greg
Thanks,
Greg
I've never tried this before...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I currently have one wheel speed sensor on the RR. (It is interesting to see the "speed" difference just from tire deformation differences when accelerating vs. braking when compared to GPS speed.)
Greg
Rennlist Hoonigan
which cost no drachmas
You would not be able to do it with a one "tooth" wheel. I'm guessing you would need 30 or more. I believe some cars are now north of 100, lots 64 or more. Slip is what the ABS uses to figure out when to work the pump. I would have to think about, but I'm not sure if you could do that in the dash with how it will let you calculate math channels. I know you could do it on a MoTeC system.
Basic Site Sponsor
Basic Site Sponsor
Matt, you'd need four wheel speeds, but you could build an alarm if the speed on an axle or a corner went out of range, could you not? Easy in MoTeC, with Ground Speed and Drive Speed.
Greg, how does the ABS work if there is only one wheel speed? How does it trigger the pressure release if it can't know which corner (or axle) is slowing more than the others?
The same trigger for the ABS in modern cars is the trigger you would need to build or see to integrate it into the logger, I would think.
It sounds like you have an OE abs system w/ wheel speed sensors, but no way to splice into it w/ the aim, hence the single RR wheel speed sensor? Not being an expert in AiM systems, i can't answer specifics, but purely from an instrumentation/signals point of view I think I can offer some insight.
Not sure if you're trying to do this on a quick diagnostic basis for setup or to "permanently" install something and have an in-car readout to adjust bias while driving. For the former, the existing pressure sensors and manual data review would probably be easier, looking for a ripple @ X hz under braking on either channel. However, reliably teaching a computer to recognize that waveform would be another thing.
For the latter, like others said wheel speed is probably your best bet. Do some research on the wheel speed sensors used by the ABS system and what sort of signal those are sending and how to interface that with AiM. Alternatively, looking at some pictures of a 944 ABS pump, it looks like there is some external wires to the solenoids for front and rear that you can tap into. These should give you direct feedback of which axle the ABS activating without any of the data noise from the rest of the braking system. Heck, if you do that you could probably bypass the AiM altogether. Just wire an LED into each of those solenoid circuits.
I only have 1 AIM wheel speed sensor today on the right rear. One pulse per rotation.
"It sounds like you have an OE abs system w/ wheel speed sensors, but no way to splice into it w/ the aim, hence the single RR wheel speed sensor?" -- Correct
I'm looking for a method to set the brake bias to insure that the front tires lock up before the rears. I now have the same (larger) size tires on all four corners and added Big Reds to the front this winter. At the very least I now have way more front traction with the bigger tires than the stock tire sizes, so the rears are more likely to lock. Even though the piston sizes are the same on the new calipers the larger rotors might add some brake bias to the fronts. So I'm looking for a method to set the brake bias without flat spotting a set up tires testing, or risking a high speed spin with the ABS disabled.
Thanks,
Greg
Let me think about monitoring the ABS solenoids. That sounds easier.
Thanks,
Greg
Your effort to ensure proper biasing is notable and worthy; many screw that up when modifying brake systems on track cars with ABS, ruin the brake performance, and blame it all on the ABS.
For on-track use... yes, monitoring wheel speeds is the correct way to go. If you simply track brake pressures (and brake pressure sensors aren't cheap!), you're not taking into account any erroneous operation of the ABS unit, likewise monitoring solenoid activity. Nor would solenoid/relay activity tell you which end locks first.
You also wouldn't be removing possible influence of the ABS unit on brake proportioning, if it does that (most do, these days).
If I were doing it without wheel speed logging - I'd probably be inclined to pull the ABS fuse and do some straight-line threshold brake applies on a skidpad, service road, or comparable test surface. Of course, you'll want to have some finesse with the brake pedal - maybe do some with ABS first, see where the threshold is for actuating ABS, then once you can just brush that level consistently, do it without ABS and see if the car starts to wiggle as you get close to the limit...
Basic Site Sponsor
Basic Site Sponsor
Vaughan, thank you for your post.
OP, Vaughan is particularly well qualified to address this.
Driving Historic cars, often not set up properly, I use a kinestheic “gauge” to weigh brake balance. I think you can develop that, with some of Vaughan’s suggestions.
What you don’t want is for the back to become unstable, period.
Rennlist Hoonigan
The challenge with the AiM math channels is that we're limited to bias and linear corrector. You could probably do it with a few bias channels, but it wouldn't work as well as it does in a MoTeC dash. The math on ABS gets a little little deep when it's selecting the wheel speeds.
IMHO, for the average DE drivers, save a few sets of worn out tires and then do some braking exercises. You'll quickly learn how to get near lockup, lockup, and how to peal out of it. Lucky for us in the NE (and you this week!), snow is awesome for learning vehicle dynamics with the lower mu.
