Mxl2 what harness ?!
My last car came with a dash new one won't
Does the harness that comes with the dash have 4 analog inputs (bps, tps, oil press, water temp) or do you have to buy the extended harness?
Same question re cameras will be running 3
Smarty HD front, smarty back, smarty gp driver view
Rennlist Hoonigan
which cost no drachmas
The expansion harness adds 4 analog inputs, 2 digital outs, a second CAN, rs232.
For the cameras, you will need a data hub that will go into the expansion plug and then the gps and 3 cameras will go into the data hub.
Basic Site Sponsor
Basic Site Sponsor
Received 2,800 Likes
As Matt says on the Data Hub, but I will tell you that the Data Hub WILL NOt supply enough power to keep all three cameras charged, ESPECIALLY the GP (smaller battery). You will need a second Data Hub with 12V power or a 5-pin power cable with diode and another Data Hub to make this work.
I have more than three dozen multi camera setups out there and this is a known issue.
The 22 pin expansion harness (have 2 in stock) has 4 AV inputs, 2 additional wheelspeeds, One Digital out and a second CAN.
So we just get a powered hub and problem solved?
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
