Cleaning inside of wheels help needed
My new 91 C2 has 2 year old Kinesis K10 wheels which the PO did not clean regularly. I had them disassembled and am having the center, which was the anodized grey, acid washed and painted artic silver. I am trying to clean the inside of the wheels but cannot get it clean. I have used Simple Green undiluted and that seemed to start the process, but dirt and road debris remains. What solvent can I safely use? I need to be careful since the outer portion is chromed...
Thanks!!!!!!!!
Thanks!!!!!!!!
i did use sikkens M700 on my wheels and they do look brand new!!!!
Anti-static silicone remover sikkens M700
i do not know what it is excactly but it cleans all porous of varnish of the wheels!!!!
simple as that a m a z i n g !!!!!!
you really need though to do some research by yourshelf since i was not able to provide you with more details of this product. most bodyshop facilities can provide you
Use this http://www.topoftheline.com/32ozwheeltir.html
Dilute it slightly with water at first then sponge it on the areas you want cleaned, let it dwell a few minutes then agitate with a brush and rinse.
If that doesn't do the trick then use it full strength.
I use the same cleaner on all my Ferrari, Maserati and Porsche wheels and have so for years so it's safe for chrome, clear coated wheels. Sponge it on aluminum wheels.
Anthony
Anthony
I found Wurth Citrus degresser straight out of the can works wonders.
