Rust on Rotors after Wash
I get, like everybody else, rust on the rotors of my 2013 Carrera S after a wheel cleaning. I use Adam's Wheel Cleaner. Once the rotors dry I drive the car applying the brakes to remove the rust from the rotors. But then I have to "dry" clean the wheels to remove the rust on them. Solutions? Any opinions about Hyde's Rustopper? Good or bad? Thanks.
I use it. It helps but doesn't remove it completely from the first real breaking event!
Received 5,388 Likes
A MasterBlaster from Detailers Domain helps me a ton.
Best solution is a wheel coating, so Opticoat, CQuartz, Kamikaze. With this you don't have to apply every wash, should last you a year or two, even with the high heat.
Originally Posted by Neun 11
How well does that sealant work? Does it help keep the barrels cleaner? You have to reapply it each wash? Thanks for your suggestion.
