Wheel Wooolies questions
I bought a 3 piece set of the original Wheel Woolies. The only one I use is the large brush (18" I believe). I now see a lot of people making these.
Are the other brands any good? Which brands are good?
Is there a source where you can just buy the large brush and not a 3 piece set?
Has there been newer innovation since the Wheel Woolies that has come out?
From what I understand, companies like Adams have went to Wheel Woolies to have their name put on the Original Wheel Woolies. Personally, I would stick with the original because mine have lasted many years with frequent use.
Braunautomotive makes the Wheel Woolie, so you could try and contact them. See if they will sell you just one.
There have been some innovations, specifically the Microfiber Madness Incredibrush Flat, however, it is also $50, so you are paying quite a bit for a very similar product. The EZ Detail Brush is $25 which works well and I believe was out before the wheel woolie, however, I don't like that it sprays product back at you.
