Replacing the Diesel Fuel Filter
Inspired by gnat this article discusses how to replace the fuel filter on a diesel Cayenne. Diesel fuel systems operate at very high pressures so that any water or dirt that gets to into the fuel system can be very bad and expensive to repair. To protect the fuel system a fairly substantial fuel filter is provided. The filter traps dirt and allows any water to collect at the bottom of the fuel filter housing. On the Cayenne it is located in the engine compartment on the passenger's side as shown below.
https://cimg3.ibsrv.net/gimg/rennlis...3450fa7b4e.jpg Porsche requires that every 10K miles the fuel filter housing have any water extracted from the bottom of the fuel filter housing and that the filter be replaced every 20K miles. I just replace the fuel filter every 10K miles since the filter has to be removed to extract any water from the fuel filter housing. The Porsche filter used for the diesel is P/N is 958 110 134 10 or its OEM equivalent MANN PU8007 at half the cost. The filter is shown below. https://cimg5.ibsrv.net/gimg/rennlis...3e989d05a1.jpg You will need a T20 torx male bit and an inch pound torque wrench to remove and replace the five fuel filter top screws. https://cimg6.ibsrv.net/gimg/rennlis...cd8bf032f1.jpg It is nice to have a tool to remove the plastic cover clips. https://cimg1.ibsrv.net/gimg/rennlis...8066f46723.jpg You will also need some type of extractor to remove any water from the bottom of the fuel filter housing. I used an oil extractor from my boat. The steps to replace the fuel filter are roughly as follows:
