Changing ATF fluid
From the manual - which is where that picture came from: (My comments in italics)
WM 370235 CHECKING AND TOPPING UP ATF (ALL MODELS) > INFORMATION > TEST CONDITIONS AFTER OPENING COOLER LINES ATF cooler lines were opened. For example: when replacing the transmission, changing ATF, changing ATF lines, replacing ATF cooler, replacing ATF thermostat. Warm up transmission in lower load range. Switch all transmission ranges several times while doing so. Read out the ATF sump temperature using the PIWIS Tester. The ATF temperature must be 100 °C (cooling system open). Let ATF cool down to approx. 35 °C. Selector lever is in position P. Press the brake pedal and shift the gear lever slowly through P-R-N-D three times. Hold the selector lever in each position for 2 seconds. Test and filling procedure at idle speed with air conditioning switched off. Then it follows with: WM 370235 CHECKING AND TOPPING UP ATF (ALL MODELS) > CHECKING ATF 1. Move selector lever to position P and start the engine. Place oil collection pan underneath. WARNING: Hot fluid 1. Danger of scalding → Let the fluid cool down. → Wear personal protective gear. Information For details of the next steps, read the test conditions specified under → INFORMATION - section on "Information". 1. Information A certain amount of oil will always be lost after unscrewing the oil inspection plug. The reason for this is that some oil remains on the plug in the lifting tube . 2. Unscrew oil inspection plug -1- . 3. The oil level is correct when ATF is dripping continuously from the lifting tube. If this is not the case, add more ATF. → TOPPING UP ATF - section on "Topping up" 4. Screw in oil inspection plug -1- with a new seal. → Tightening Torque: 16 Nm (12 ft. lb.) +/-1 Nm (+/- 0.5 ft. lb.) Fig 2: Identifying ATF Inspection Plug And the image you have is shown.. And to finalize the confusion: WM 370235 CHECKING AND TOPPING UP ATF (ALL MODELS) > TOPPING UP ATF Information For details of the next steps, read the test conditions specified under → INFORMATION - section on "Information". Information A certain amount of oil will always be lost after unscrewing the oil inspection plug. The reason for this is that some oil remains on the plug in the lifting tube. 1. Move selector lever to position P and start the engine. 2. Place oil collection pan underneath. WARNING: Hot fluid 1. Danger of scalding → Let the fluid cool down. → Wear personal protective gear. Information For details of the next steps, read the test conditions specified under → INFORMATION - section on "Information". {Ya gotta love information that tells you to read "Information"..} 1. Information A certain amount of oil will always be lost after unscrewing the oil inspection plug. The reason for this is that some oil remains on the plug in the lifting tube . 1. Unscrew oil inspection plug -1- . Fig 1: Identifying ATF Inspection Plug (once again - the same damn image appears..) 3. Screw adapter for filling oil Adapter For Filling ATF Oil VAS 6262/2 WE 1390 into the ATF pan hand-tight. 4. Connect adapter for filling oil Adapter For Filling Oil VAS 6262A WE 1389 to the rapid-action coupling and fill in ATF. 5. Pull off adapter for filling oil Adapter For Filling Oil VAS 6262A WE 1389 at the rapid-action coupling and check to see if ATF emerges. 6. There was no #6.. go figure.. 7. If no ATF emerges, fill in ATF until a constant discharge is visible at the lifting tube -2- . 8. Allow the ATF to drain for as long as required until the ATF is still only dripping continuously. Screw in oil inspection plug -1- with a new seal. → Tightening Torque: 16 Nm (12 ft. lb.) +/-1 Nm (+/- 0.5 ft. lb.) Fig 2: Identifying ATF Inspection Plug And of course the image you already have shown.. My thoughts on the "pipe" assembly. It appears that the inner part of the drain plug - the pipe (Part#2 - the gray part) - can be removed from the plug in order to actually drain the entire transmission. Otherwise it stays in the pan when the plug (yellow part) is removed. The manual somewhere makes mention of removing the filler tube using an allen wrench. I'll point this thread out to someone who did change his fluid about a week ago and see if he has any comments. Apparently the fill is slightly different if you've disturbed hoses to the cooler. Might I ask why the cooler was replaced? Just curious.. |
My car was in an accident. The power steering cooler , transmission oil cooler, radiator, radiator fan and condenser were damaged. We replaced all these so I decided to flush the transmission fluid as well. I was able to drain the fluid by unscrewing the so called inspection fluid. I will try to get the pipe removed using allen wrench tomorrow. However I haven't identified the fill plug. The pan has no fill plug like it used in 955 models. The manual doesn't show how (where) to fill the fluid... 3. Screw adapter for filling oil Adapter For Filling ATF Oil VAS 6262/2 WE 1390 into the ATF pan hand-tight. I need to know where to hand-tight the adapter...There is only one plug in the pan which is the inspection plug... where is the fill plug!!!! http://www.renntech.org/forums/topic...e/#entry272616 |
In preparation for eventually changing my CD's ATF I picked up Mityvac MVA7216 ATF refill kit :
http://www.tooltopia.com/mityvac-mva...lQchoCJDPw_wcB. It has the numerous fill adapters. https://cimg0.ibsrv.net/gimg/rennlis...767539afdf.jpg Mity VAC ATF Refill Kit https://cimg3.ibsrv.net/gimg/rennlis...867cbd419d.jpg Adapters. Cayenne uses MVA585 M10 X 1.0 https://cimg6.ibsrv.net/gimg/rennlis...03b9054f3c.jpg The Cayenne MV585 adapter is the upper adapter |
I'm assembling my list of things to buy, and I'm leaning towards the VW G055540A2 fluid but haven't decided completely yet. ;)
When I change my ATF I'm most likely going with Ravenol J1D2122 or the Febi 29934. The Febi bottle shows Porsche P/N 958 300 540 00 apparently. Blau sells a kit F2A1044-C with 9 qts of Ravenol, filter, pan gaskets and seals, $320 from Amazon. The filter is by Meyle- WulfGaertner AutoParts AG. I'm going to buy the Porsche filter and gaskets from Sonnen and the Ravenol from Amazon ($164 delivered).
My local dealer confirmed the Porsche ATF comes in a bottle labeled G055 540 A2. |
I questioned my local dealer about use of plug #19 to fill the transmission. They came back with essentially the same procedure posted above which says to fill through the drain plug in the oil pan. The drain plug is M10 X 1 X 9. In the Mity Vac refill kit the M10 X 1 is adapter MVA585 which they call a VW ATF refill adapter. My dealer further confirmed #19 is inaccessible when the transfer case is installed!! doh.
https://cimg8.ibsrv.net/gimg/rennlis...850e9e210e.png |
Here is the fluid I plan to use: RAVENOL T-WS Lifetime Fluid
http://www.ravenolamerica.com/transm...ifetime-fluid/ |
The Ravenol J1D2122 fluid crosses over to the VW fluid G 055 540 A2 which crosses over to the Porsche fluid 958 300 540 00. Whew.
My dealer has the Porsche fluid for $82 a bottle and can get the VW fluid for $25 a bottle. A Ravenol case of 12 works out to less than $14 a bottle. |
Some helpful notes for those trying this:
Removing the drain plug and the plastic riser will drain about 4 liters. About 2 more liters drain when removing the pan, making it 6 liters total that can be removed without opening the cooler lines. That's a little less than half the capacity. To deal with this I drained 6 liters, refilled with 6 liters of fresh fluid, then ran the trans for a while, then re-drained and re-filled again with 6 liters. I wonder how much more can be drained from opening the cooler lines... they were just too difficult to reach to make it worth the effort as the forward driveshaft from the transfer case is in the way. The ECS Tuning 3 liter Filler System makes the job a lot easier, as it includes a quick-disconnect fitting that threads right into the pan (their version of a VAS 6262/2). It's so easy to drain and refill with this tool that I'll likely do another 6 liter swap in 5,000 miles to get more fresh fluid in there. An infrared meter is not accurate especially if you measure the low point of the oil pan - it's about 6 degrees C off from what the PIWIS2 computer system reports which means if you wait for 40 on the infrared meter at the bottom of the pan, it's really around 46-48 degrees C in the trans. Is the original Porsche trans fluid red to start with? If so, at 96K miles, mine was brown and opaque and the magnets were full of tiny shavings that looked like clay. |
958 Cayenne DIY: Changing ATF fluid (development thread)
This is a thread created from various postings in the Cayenne 958 forum - in thread: https://rennlist.com/forums/cayenne-...id-change.html
This thread will reside in the general Cayenne DIY forum, and will be closed. I'll monitor the other thread (which remains open) so if anything significant is added to it - I will add it here. Any comments/corrections to this thread - please send me a PM.. |
Thanks to the coaxing of one of our members (R553) - who gathered most of the info - we now have a table of fluids that are listed as compatible with the 958 8-speed transmission, and the part numbers for parts required to drop the transmission pan, replace the filter and refill the transmission.
Fluids:
(12 Liters Ravenol $164 Amazon ) Blau ATF kit for 8 speed Cayennes F2A1044-C with 9 liters of Ravenol, filter, pan gaskets and seals, The parts are OEM, not Porsche($320 from Amazon) Bonus part numbers & torques:
Thanks again Rob! :bigbye: |
I received the ATF gaskets, filter, fill tube and o-rings today from Sonnen. The filter is Japanese Roki co brand with a P/N of PA66 - GF33.
Here are photos of the parts. https://cimg1.ibsrv.net/gimg/rennlis...29502a2bfa.jpg ATF Filter with Porsche PN https://cimg7.ibsrv.net/gimg/rennlis...ab2b5b9515.jpg ATF Filter Manufacturers PN https://cimg1.ibsrv.net/gimg/rennlis...2b93c19336.jpg Pan Gasket https://cimg6.ibsrv.net/gimg/rennlis...45b2bc3d3b.jpg ATF filter o-ring, drain plug and drain plug gasket https://cimg0.ibsrv.net/gimg/rennlis...9102e698b1.jpg Oil tube ( bought as a spare ) |
Originally Posted by r553
(Post 14496875)
https://datasheets.globalspec.com/ds...5-620837B297E9 I'm not sure what the 4R16 refers to.. |
