Differential Fluid Service (Front and Rear)
Old 08-17-2017, 02:28 AM
projekt-h
projekt-h's Avatar
Default Differential Fluid Service (Front and Rear)
"How To" Change your differential fluid in a 958 Cayenne.
From my understanding, this process should be the same for all 958 models.
There may be differences in fluids between them, or for personal preference.
What You Will Need:
- Your 958 (Freshly polished to get dirty hand prints on yields most authentic DIY experience)
Tools
- 3/8" Ratchet (Lowest profile head you can get)
- 10mm socket and/or T30 Torx bit
- ~6" extension
- 8mm Stubby hex bit (a carefully chopped 8mm allen wrench will suffice, but won't allow you to use a torque wrench)
- 3/8" Torque wrench that allows up to 26 ft/lb (35Nm)
- Fluid transfer pump
- Drain Pan (I'd recommend using 2)
Fluid:
- 3 Liters of required or preferred gear oil. (Shouldn't need more than 2, but order 3 to be safe)
Other:
- New drain and fill plugs (all 4 are the same part, takes the same part as 955/957, total of four to do both differentials. I'd hold on to the old ones just in case)
- Good Music (to individual taste)
*A means of lifting the car while keeping it level is highly recommended. Many have mentioned raising the air suspension to it's highest level for servicing. Mine has standard suspension and I was able to do this all on the ground.
*Performing service when cold is recommended. Sticking your hands and face in the hot underbelly of the beast is not pleasant. Gear oil is bad enough, hot gear oil is miserable. Additionally, aluminum housings and steel bolts have different expansion rates when hot, taking that variable away allows this to go more smoothly.
What to do:
1. Remove Belly Pans (No photos of process or under car. Sorry)
From the front, use your 10mm socket (or T30 Torx) and remove the bolts holding in the belly pan. There's two further up the sides of the front pan. *I'd recommend removing the two higher ones first, then do the rear "row", then do the front "row" to prevent belly pan falling on your face.*
For the rear pan section, go at it from the side and loosen the two bolts on the rear. No need to remove them, or the brackety piece they go to. Remove the two located around the middle of the pan and slip it out frontwards to remove. Be mindful of how the rear attaches into the bracket.
The plastic in my left hand is the "brackety" piece from the rear of the pan that holds the pan to the crossmember that doesn't actually need to be removed:
2. Front Differential
Front Differential, underneath, facing rear of the vehicle.
GREEN = FILL / BLUE = DRAIN
The front differential is towards the right-hand side of the vehicle.
Remove the Fill plug first. It will allow fluid to drain easier, and in case you can't get the fill to break free, you definitely DO NOT want to drain it.
The fill plug on the front differential is the only tricky part in this whole process. This is why you need the stubby hex and the lowest profile ratchet possible. Finagle it up in there. I had the best luck getting in from the inboard side, ratchet sideways, go above it, then rotate and come down and into it. Silly process, I know, but finagle around in there and do what works for you.
It'll take some umph to break free. Go about one or two full rotations, then pop the tool out and pull the bit off, at this point you'll want to just remove it by hand with the hex bit.
At this point, you'll suddenly be reminded how bad gear oil smells and go throw rubber gloves on so the terrible stank doesn't get stuck in your hands again.
Remove the drain plug with the pan underneath the vehicle. While that's draining, go ahead and remove the fill plug first, then remove the drain plug from the rear differential and let that drain if you have the 2nd pan. If not, just do this one at a time.
Once empty, install a new drain plug and make sure you use a properly calibrated torque wrench set to the correct torque spec.
Once you get that in, use the transfer pump to get the new oil into the differential. It's fill-to-overflow, so keep going slowly until fluid starts coming out of the fill hole. Let that do it's thing, and when no more is oozing out of there, install a new fill plug. You may not be able to get a torque wrench in there. If you can't, do your best to calibrate your arm from installing the drain plug and use your best judgement. (for filling mine, the hose on the pump barely fit in the hole, I pumped the whole liter in, and when I pulled the hose out all the excess that was stuck came pouring out. I don't know the exact capacity, but I know it's less than one liter. Anything it can't hold will just flow out)
Get some carb cleaner or brake cleaner on a rag and clean up as much of the mess on the housing as you can. Any exterior residue will really stink when you're driving and the differential gets up to temp. This applies to the rear procedure as well.
Rear Differential
Same process as the front, but with MUCH easier access. As always, remove the fill plug first.
Photo of rear differential, taken from rear of vehicle facing forwards:
Standard DIY Disclaimer: (borrowed from deilenberger) You may be an ape with a wrench. It's possible you should never be in the same garage as a car when you're holding a wrench. Therefore - what I just described is what I would do - not what I'm suggesting that you do. If you break it, bend it, pork it up, kill yourself doing it - I never told you to do it. I just told you how I'd do it. You're a big boy - man up if you screw up.
It's late, I'm very tired, and sure I forgot something. I'll edit/refine/add to this tomorrow. (posting now in case my computer decided not to save it)
projekt-h is offline
The following 3 users liked this post by projekt-h:
DemonBG (04-16-2020), Guards_Red_991 (03-11-2023), RhinoComp (10-27-2023)
Old 08-17-2017, 02:42 AM
AGARubberDuck
AGARubberDuck's Avatar
Thank you for this write-up with pics! One question for clarification, is this the PTV+ diffs or standard? Presuming standard as you mentioned being on steelies? The other question would be, is there a significant difference in this procedure between standard and PTV+?
AGARubberDuck is offline
Old 08-17-2017, 08:46 AM
projekt-h
projekt-h's Avatar
Thank you! First time doing one and it got late, I'll be refining it later today. This was for the standard differentials, as far as I've seen, PTV+ should be pretty much the same process but with different fluids. Don't remember being on steelies... my wheels aren't that basic lol.
I'll do some more digging and try to find the exact differences between standard and PTV+ for future reference.
Old 08-17-2017, 12:12 PM
AGARubberDuck
Haha, not what I meant. I was referring to the steel springs, vs PASM.
My understanding is the PTV+ diffs are the ones commonly having issues, but a crunching symptom vs whine. I'll get under mine this weekend and have a look, see if pics look like mine.
Old 08-17-2017, 12:46 PM
deilenberger
deilenberger's Avatar
Received 1,140 Likes on 758 Posts
THANKS MUCH for the excellent DIY (and the quoted disclaimer!) I've copied it to the Cayenne DIY forum - which can be found on the main level menu, or in a link in the stickies up top.
deilenberger is offline
Old 08-18-2017, 12:13 AM
projekt-h
projekt-h's Avatar
For what it's worth, I'm still getting the same noise out of the front end. Rotating my tires tomorrow to see if that's a factor in this (doubtful, but worth a try)
I'm going to do some more research, and possibly try something with a friction modifier for the front and see if that helps. Will report back with results.
Ahhh gotcha. From what I've read you are correct on the PTV+ diffs being problematic. I can't find MUCH online, but from what I can tell, and what my "experience" tells me is that it will be very similar on the outside. Probably use the same plugs. I'm sure there's a different fluid required for the PTV+ than the fairly standard mine uses. My guess would be something with a friction modifier.
Awesome, thank you! Glad I could contribute!
Old 01-25-2018, 07:58 PM
CarGuyNVA
CarGuyNVA's Avatar
Default Update: PTV+ Porsche Fluid Part #
Just wanted to note here in this DIY that the updated part # for the genuine Porsche diff fluid for PTV+ equipped Cayennes is 000-043-300-37.
CarGuyNVA is offline
Old 04-15-2018, 02:51 PM
fox32223
fox32223's Avatar
So I drained my rear diff fluid today and I have PTV+. I collected it so i could measure it. I measured about 1.3 liters.
Heres the problem, I filled till it overflowed and it took less than a liter.
I let it sit for a hour and went back to add more and it still wouldn't take any more oil.
Is there a hidden fill plug further up the case or on the top ?
Update:
Well, here's what I learned.
If you just pump the oil in till it drains back out you can only get 0.5 liters in.
When you have PTV+ you'll need to have the Cayenne off the ground and be able to spin the tires.
After spinning-adding oil, spinning-adding oil, spinning adding oil, I finally got 1.4 liters in to the point where a little oil was draining back out even after I spin the tires.
So yes, it does take what the book says.
Apparently this removes the air pockets and moves the oil around to places it needs to be.
fox32223 is offline
The following 2 users liked this post by fox32223:
deilenberger (04-27-2020), Sam_M (09-28-2023)
Old 11-21-2018, 05:04 PM
kennyt
kennyt's Avatar
When do you guys replace the differential fluid? Year or mileage? Mine 2013 CTT is at 68k miles.
kennyt is offline
Old 04-02-2019, 11:24 PM
Y2kaibo
Y2kaibo's Avatar
Default Diff fluid
I do not have the ptv+. Is it ok to use Mobil 1 75w-90 for front and rear diffs? Or should I use oem Porsche fluids? Any I’ll effects with Mobil 1? How often is the diff fluid change needed? Do I have to fill and roll the wheels and fill and repeat or is that only for ptv+?
Y2kaibo is offline
Old 04-04-2019, 03:34 PM
Cruk958
Cruk958's Avatar
Hi everyone. New here. Also, new to the Cayenne. I am planning to do this fluid change soon, but wanted to know if you all could explain what "PTV+" means.
Thanks!
Cruk958 is offline
Old 04-09-2019, 05:24 PM
deilenberger
Thanks!
PTV = Porsche Torque Vectoring - which is an active rear differential where the computer driving the vehicle can command the differential to send more power/torque to whatever wheel is the outside wheel in a turn to effectively push that side of the vehicle around the turn faster. It tightens cornering. It's an expensive option, and those differentials are prone to clutch-chatter.
Old 04-09-2019, 06:08 PM
Cruk958
Cruk958's Avatar
Talking
Thanks for the clarification. With that info, I did some more searching... found another thread... searched... ran the VIN and didn’t see anywhere in my option where I have an obvious code for PTV or PDCC. (IMAGE ATTACHED).
So, when doing the fluid change, would the “tire spin” technique be necessary for a non-PTV?
Motul has two gear oils - LS and non-LS... I am not sure if my CS is limited slip or not. Any advise?
Also, anyone have the part code, or link for part, for the replacement drain plugs? Searched (a lot) and found nothing.
Thats a lot of questions. Sorry. Thanks for any help
Cruk958 is offline
Old 05-25-2019, 11:21 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,733 Likes on 1,637 Posts
does anyone have a picture of the diff drain plug washers.
I want to do this but didn't order the washers and have a million other washers here for the slew of German cars in this garage , jk.
I'll be adding to this thread if needed.
Also, wondering hy the op states to remove the fill plug first as All Data doesn't have us doin it that way. I have to agree that removing, or at lest loosening the fill plug first is a great tip. It guarantees that you don't drain a diff that you can't fill and maybe it also makes for a better drain flow of the fluid.
RAudi Driver is offline
Old 06-02-2019, 07:22 PM
TheUnscented
TheUnscented's Avatar
Today I (finally) changed my oil, transfer case fluid and fluid on both the front and rear differentials. Took me four hours from preparation to putting the final tool away. This was a fantastic write up, thank you!
I'd ordered the plugs (P/N 955-332-057-00 ) from Gaudin Porsche ($12.39 x 4). There were no crush rings or washers on the new plug nor the ones I removed. (see photo) Unlike the TC plugs, there didn't seem to be any sealant, and the ones coming out had the flange against the diff housing. Not entirely certain why I needed new plugs but I don't want to need a new differntial. The front differntial fill plug: I'd bought a low-profile rachet and stubby hex driver---still wouldn't fit. Ended up using an 8mm bit with a racheting bit driver (see photo), the only downside being that the final torque was a guess. The other three plugs had plenty of clearance.
I'd read the write up wrong thinking I needed 2-3 liters per differential. The front diff seemed to accept about 0.9 liters (including what remained in my Harbor Freight fluid transfer pump) and weeped out several ounces once hose removed. The rear diff was much easier and seemed to accept maybe 1.3 liters. The vehicle was perfectly level. So out of the six liters I'd purchased, I have about 3.6 liters left.
CTT Differnetial plugs
TheUnscented is offline
Quick Reply: Differential Fluid Service (Front and Rear)
