2021 Cayanne S performance tune
Looking for a tune for my 2021 Cayanne S. I tuned my 2022 911 C2S with m-engineering and have been very pleased. It was great gains and I went with a more conservative tune for my 911.
M-engineering will tune the 2021 Cayanne S, but both them and FABSPEED want you to send in your ECU… which becomes a massive pain if/when I need to take it back to the dealership for service in the future and need to flash back to stock.
Anyone here using a tune on their Cayanne? Run into this issue? What’s the best option out there?
APR offers a flash through the OBD2 port. Individual installers available nationwide.
From this thread:
https://rennlist.com/forums/cayenne-...-upgrades.html
http://goapr.io/9y29
We're excited to announce our Engine Control Unit (ECU) Upgrades are now available for the Porsche Cayenne S and S Coupe (9Y) 2.9 TFSI engine with the Bosch MG1 ECU! Expect massive gains with up to 484-538 HP and 521-590 FT-LBS of torque on tap, depending on octane, from this simple software upgrade.
Our new suite of MG1 ECU software comes after months of extensive research and development that is typically absent from the aftermarket. Our upgrade makes the engine more powerful and more exciting. We’ve extensively calibrated the system to work flawlessly on the track, while retaining safety routines to protect your engine in the most demanding scenarios. This was all made possible by our engineering team's pursuit of perfection. Development vehicles were outfitted with additional sensors, including turbo shaft speed sensors, thermocouples, transducers, and more, along with our high speed direct RAM logging equipment, to feed valuable data to the team for analysis. After thousands of hours of testing and tuning we created new calibrations that are fine tuned for several octanes and contain hundreds of map changes, with a vast array of safety features built in.
Feature Overview:
From this thread:
Feature Overview:
- Delivers up to 484-538 HP with 521-590 FT-LBS depending on octane
- Max gains of +80-135 AWHP and +108-179 AWFT-LBS depending on octane
- Supports 91 AKI, 93 AKI, 100 AKI, and 104 AKI fuel grades
- Optional factory term limit matching limited powertrain warranty with APR Plus
- Standing RPM soft limiter increased
- Left-foot braking / brake boosting added
- Properly rescaled performance gauges
- Optimized thermal management and protection
- Optimized launch control strategy for faster response
- Optimized driveline protection during launch
- Optional exhaust crackle in sport mode (Similar to sportier models)
- No hardware required (Software only)
- Supports standard bolt on modifications
- Eliminated the need for a TCU upgrade to achieve full torque
- Free lifetime updates
- Direct OBDII port flash (No ECU removal)
- 30 day money back guarantee
From this thread:
Feature Overview:
From this thread:
Feature Overview:
I installed a JB4. About to uninstall it for 2 year service.
@Arin@APR I called APR today and they said my year model (2021), after march of that years production, the ECU was locked differently and, If my ECU is one of the newer models (which I think it is), then y’all do not have an easy tune for my car…
does that sound correct?
I've heard the same thing, they can tell you whether they can tune your car by your VIN I believe. I imagine they'll find a workaround eventually.
edit: typo fix
edit: typo fix
LDT (11-09-2022)
You should change the numbers in the table to show the delta values between normal and tune dyno results.
Delete, somehow got in the wrong forum.
From this thread:
Feature Overview:
From this thread:
Feature Overview:
My mechanic highly suggests ECU over the OBD style, saying that you have more control on what is being tuned and getting the correct readings air/fuel or shift points etc...
OBD tune; easier to add or subtract, cheaper
ECU tune; more exact, and more variables to tune with, or customize
I'm out of Porsche warranty, but do have aftermarket service warranty. Do either of these effect that (I know I need to read the fine print again!)
A piggyback, such as the JB4 Plug and Play, intercepts and modifies various sensor signals to the ECU. As you said, it tricks the ECU into thinking the values are not optimal and then causes it to produce more boost or inject more fuel - thus giving more power. The ECU is not modified in any way; it retains the original factory tune.
An ECU tune, or flash tune, modifies the factory computer programming to produce more power. It alters many more parameters than a piggyback tune. The program can be installed most easily via the OBD2 port. Another way to flash the ECU is to remove it from the vehicle and send it to the tuner for modification. The end result is the same; A generic “Stage 1” tune for that specific model that gives moderate performance gains using the stock factory engine.
If you want to add larger turbos, injectors, etc, you’ll need a custom “dyno tune”. This is a customized tune for your specific vehicle modifications and tailored to your preferences and tolerance for risk.
metelhead (Today)
