GRR - CEL Code @ 654 miles on new '21 Cayenne
GRR - CEL Code U0122 @ 654 miles on new '21 Cayenne
grr grr grr
CEL (Check Engine Light)
OBDII reader says code U0122 - Lost Communications With Vehicle Dynamics Control Module
will be fixed under warranty - but sheesh - less than 1000 miles and the car is already throwing codes…
guess we'll have a service appointment next week {sigh}
7/17/2021 Update
7/17/2021 Update
- workaround? don’t externally charge your EV until Porsche has a software fix - this suggested work around currently being tested by myself stay tuned
- known issue - Porsche claims future software will resolve this issue
- fleetwide issue - not unique to your vehicle
- sporadic - no known method to cause it
- safe to ignore if you can determine it’s this code
- we’re looking for data on this issue from other owners on this trhead - turbo only issue? or non-Turbo also?
- very very unlikely your dealer can ‘fix” this issue unless it is really a problem with the vehicle dynamics module
- explanations later in this thread
- don’t like your new ‘21 Turbo S eHybrid - great this is your get out of jail free card! Porsche will most likley have to buy the car back if you encounter this issue and they can’t fix it - and to date no fix is deployed.
vehicle delivered to Porsche Service today - will update this thread once they diagnose.
aloktayi (01-01-2023)
Your Taycan is jealous of the new girl in the garage and sent over a virus.
The following 2 users liked this post by Needsdecaf:
Booth9999 (06-30-2021),
daveo4porsche (04-27-2021)
Val One time fault for p075200 Shift solenoid A stuck
(inactive fault)
Performed a transmission shift calibration per test plan.
80tu
Test drove the vehicle around the block to verify shifts 1-8 are normal
(inactive fault)
80tu
anyone seen this before?
grr grr grr
If too many of the faults occur, CA gives you a superior lemon law remedy (repurchase).
disappointing - car is back at dealer with CEL 2 days after they returned to us - it's likely going to be lemon'd given the logistic of virtually any fix related to the transmission taking a minimum of 4-6 weeks to get major parts from germany
my wife is sad and I'm unimpressed...
EV's are sooo much simpler, and I've never had this many problems with any Tesla I've owned since 2013 - and Porsche is supposed to be the better car.
I was hoping the issue would have been resolved with the first repair, but it doesn't look that way.
poolie (05-02-2021)
This is all I could find when googling your OBD2 error, seems repairable if that is what you want to do: When the P0752 code is triggered, it’s because the gear required by your vehicle’s ECM doesn’t line up with the actual gear when you’re driving.
Instead, shift solenoid malfunctions are blamed and a replacement is carried out in error.
What causes the P0752 code?
This code can be stored for a handful of reasons:- The transmission fluid level has gotten too low
- The transmission fluid has become dirty or contaminated
- The solenoid A valve is malfunctioning
- Shift solenoid A valve connectors or harnesses are malfunctioning
- Shift solenoid A valve circuit has shorted or is open
Common mistakes when diagnosing the P0752 code
As we mentioned above, this code may be triggered because of a malfunctioning shift solenoid circuit. In fact, that’s one of the most common reasons this code appears. However, despite how prevalent this problem is, it often gets missed.Instead, shift solenoid malfunctions are blamed and a replacement is carried out in error.
How serious is the P0752 code?
The code isn’t serious insofar as it won’t put your life in danger. However, it will make your vehicle impossible to drive because you can’t shift gears. If you try forcing the vehicle into gear, you could also wind up doing a lot more damage.What repairs can fix the P0752 code?
Fortunately, repairing the problem that is triggering this code could be relatively simple and quick:- The transmission fluid may just need to be replaced or topped off
- Shorted or burned wiring may need replacing
- Blockages within the pump may need to be cleared out
- A defective pump may also need to be replaced
I am 100% certain this issue can be repaired, but diagnosing root cause and then sourcing parts will drive the entire process well past the 30 day "out of service" period - the TurboS eHybrid is an exceptionally low volume product and shares very few drive train parts with other Porsches - sources parts from Germany in the current world circumstances is a 4-8 week affair - service manager also says Porsche will not authorize service hours to find the actual transmission component but rather replace the transmission as a whole - finding root cause is an open ended number of investigating hours vs. a known quantity of service hours to perform a transmission swap.
so it's the timeliness of the fix that concerns me not the actual ability to fix the problem - I think in current circumstances the fix duration could easily exceed 45 days - I'm not interested in sitting idly by with a new 200k SUV that is stored at the dealer for 45-60 days.
the car has less than 875 miles on the odometer and this is very disheartening.
thank you for this - I deeply appreciate the time and effort to find this information for me - I'll share it with my service manager - it would be unlikely but a happy situation if we were to find this is simply a transmission fluid issue or any of the simple 'fixes' outlined here - but I'm dubious at this point
daveo4porsche (05-02-2021)
local dealer service escalated to Porsche NA tech support today - analysis of the 2nd code is it’s completely different than the first code - new code is uncommon enough that Porsche NA is having to ask Porsche Germany what it means - it’s not a common diagnostic code or one that has come up in the past from the Cayenne fleet so no one in North America has the textual description as to what it means - we’ll have that answer by tuesday or Wed this week hopefully - random codes with no clear diagnostic steps this car is looking more and more like an actual Lemon. So far nothing on the car can be identified that needs to be fixed/changed to make the codes go away.
no update - waiting for analysis from Germany.
